Steering box noise - Defender Source
Old July 22nd, 2012, 03:56 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Steering box noise
Lately I have been hearing a faint clunk when I turn the wheel all the way to one side then back. Today I got under the truck and had someone turn the wheel and it seems like the noise is coming from the steering box. I was hoping it was the steering linkage but it looks like I was wrong. Any thoughts on what the problem could be? I have never opened up a steering box before. Do you have to grease it? It sounds like something may be loose in there.
Thanks, Jason
Old July 22nd, 2012, 04:19 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I had the same thing happening and it turned out to be the panhard rod bushings. I had to watch very carefully as a friend turned the wheel back and forth to see the movement.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
