steering box lock & adjuster nut- stuck - Defender Source
Old April 25th, 2011, 12:07 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
Can’t bust loose the larger lock nut surronding the adjuster screw…is it time/safe to use an impact gun? I replaced all the tie rod ends/joints pitman arm joint etc and still have a little too much steering play. Tried using an 18” breaker bar after loosening the steering box far enough to get a socket (with 3/8”Craftsman universal joint) on the nut…broke the joint. Soaked for days with PB Blaster…I could probably get a 1/2" universal joint or universal socket on the lock nut in order to try the impact wrench, however, I don't want to snap anything...ideas. (Can't see a lock washer crushed over the nut, similar to steering box to frame bolts, nor do I think it's reverse thread.)
Old April 25th, 2011, 01:09 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Hit it with a lot of heat from a torch and PB blast again then hit it with impact wrench. The impact wrench is less likely to break the bolt than a breaker bar......be careful with that!
It might be time to spring for a nice Meridian box.
Old April 25th, 2011, 03:48 PM
PMKColorado
Paul Koentges
not really comfortable hitting it with heat...don't want to cook the fluid or seals. D-90 only has 68K so the box should still be good...I will try the impact unless someone else chimes in...
thanks
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Steering box shaft movement after tightening pitman arm nut Neil McCauley Defender Technical Discussions 18 June 10th, 2008 02:18 PM
