Steering box LEAKSSSSS - Defender Source
Old February 18th, 2012, 06:23 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
Is there a better replacement or just buy a new one and from where or used?
Old February 18th, 2012, 06:30 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Meridian is what I was looking at.
Old February 18th, 2012, 06:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have a meriden
Old February 18th, 2012, 06:52 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Spelliing isn't one of my strengths.
Old February 18th, 2012, 06:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
Or mine
Old February 18th, 2012, 07:35 PM
323jamie's Avatar
323jamie
jamie
what was the cost? and where did you purchase it?
Old February 18th, 2012, 07:54 PM
323jamie's Avatar
323jamie
jamie
thanks, I looked up the year and vehicle but it showed for range rover for 1983. I will call them monday.
Old February 18th, 2012, 08:12 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Meridian here, as per fij's advice, still no leaks.
Robert Deniro
Old February 19th, 2012, 11:50 AM
tommyd's Avatar
tommyd
Tom
LR3
Also just got a Meridian. They were fast, and really helpful over the phone. I also wasn't sure which style to get; the guy I spoke with told me that 82-00108 is sold much more commonly than 82-00109, so that's the one I got. And it fit. For me, it was $265 + $160 core deposit +$30 ground shipping. Three year warranty. Pretty good, I think.
Steering is so much better now; I don't have to saw the wheel back and forth to stay in my lane.
Old February 19th, 2012, 12:55 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Meridian for me as well, transaction was super easy and they give you a return label and you use the same box for the core return. Samy price as Tommy above.
Old February 19th, 2012, 10:51 PM
323jamie's Avatar
323jamie
jamie
Wow, I was told to use the lucas oil and it should hold until I can come up with the full amount. (bought a radiator this month)
Old February 19th, 2012, 11:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have a weird thing going in with my steering.
New box
New pump
New lines
New drop arm.
After doing the job, one of the lines was leaking. It was leaking where the rubber hose is clamped to the metal pipe. It's the factory clamp on the line. I think this is the return line. Every time I touch the metal pipe under the clamp on the rubber hose it was wet. I figured the line was defective so I replaced it again. Same thing is going on with the new line. Could I have two defective lines or could this pipe be getting wet from somewhere else? The fluid isn't really red but if it is coming from the steering it has to be the slightest seepage leak. It's not coming from my radiator and if my oil line had a hole I would think I would see a bigger mess.
Thoughts?
Old February 21st, 2012, 07:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
So this line is leaking
http://www.roverparts.com/Parts/NTC2595.cfm
It leaks at the factory clamp on the left side. This is the second new one to leak. Could it indicate there is too much pressure in my system? It is all new and works fine but this line has seepage.
Old March 8th, 2012, 03:23 PM
323jamie's Avatar
323jamie
jamie
The major question here is are the numbers your recomending for a right hand or left hand drive?
Old March 8th, 2012, 04:26 PM
Naplm00
Matthew
Mine was doing the same thing. I ended up clipping off the clamp, cleaning up the hard pipe end and buying some bulk PS hose. Reclamping with a good quality worm clamp and bingo, no more leaks
Old March 8th, 2012, 04:30 PM
323jamie's Avatar
323jamie
jamie
The leaks appear to come from the drop leg.
Old March 8th, 2012, 04:42 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Has anyone had a Meridian box fail or need service either in or out of warranty?
Old March 9th, 2012, 12:30 PM
323jamie's Avatar
323jamie
jamie
does anyone have an extra rhd steering box they are willing to part with? I dont wnat to render my vehicle inop for the time of the repair.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
