Steering box leaking.... options? - Defender Source
Old October 20th, 2010, 05:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I know I've mentioned it before, but my steering box is leaking at the shaft. Really becoming a pain in the ass to keep refilling the thing, and I want to fix it correctly. But at the same time, I have my doubts that just a seal kit would do the job.
What's the replacement options for the box? Swapping the drop arm is no big deal...... I replaced that about 2 years ago, so it shouldn't be hard to get it off to swap over. Part numbers would be greatly appreciated, as I don't want to accidently snag a RDH box.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 20th, 2010, 07:29 PM
Replace it with a meridian reman box.
They change the bushing to a bearing to eliminate that issue.
Ron
Old October 20th, 2010, 10:30 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
As of two days ago, I'm the new owner of a '99 disco I with a bad leak at the PS input shaft. I was just going to replace the seal on it. Why do you have your doubts about a new seal?
Pete
Old October 21st, 2010, 07:38 AM
The Dro
Dro
1988 Ninety
Ron
Do you remember the price?
Old October 21st, 2010, 09:40 AM
Hans's Avatar
Hans
Hans Haase
Pete
I've been told that the bushing on the output shaft wears, and that a seal kit only holds for a short time if it's badly worn. No idea about the input side.
-Hans
Edit:
Found the online price on Meridian's website. $295 with a $160 core.
Beats NAPA by about $150
My oil line fix
Old October 21st, 2010, 02:34 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Ron is right. I went the Meridian route a few years back. Been leak free ever since and it was cheaper than OEM.
Chance
Old October 21st, 2010, 04:57 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm not saying Meridian is bad, but mine has leaks. It was about 3 years until the leaks developed.
Old October 22nd, 2010, 02:26 PM
I understood that they had a lifetime warranty.
Also, bigger tires and/or rock crawling is really hard on steering boxes (not saying that is the cause or not or whatever).
Ron
Old October 22nd, 2010, 03:19 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Anyone done a fix that involves pinning the shaft to something solid below the arm? It would seem the fault is wear due to torque on one end of a shaft that has 'insufficient' support.
Old October 22nd, 2010, 06:39 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Where can one purchase a Meridian remanufactured steering box?
Old October 22nd, 2010, 06:42 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
From Meridian, of course!
http://www.meridianautoparts.com/add.../82-00108.html
Chance
Old October 22nd, 2010, 10:59 PM
peachyracer
Peter Stolz
-Hans
Edit:
Well, I had already ordered a seal kit from Autozone for around $79 and I'll take one for the team and try it out. All I really needed out of it was the input shaft seal, but I called the $tealership and they wanted $49 just for that seal. Hell, I figgered for a few bucks more why not get 'em all. I have a few Captain & Cokes in me right now, but if i remember, I'll post updates...
Go Badgers!!!!
Pete
Old October 23rd, 2010, 10:03 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Found my receipt dated 8/2006. $295 for the box and $160 core. Over four years, and no leaks OR price change.
Chance
Old December 29th, 2010, 08:59 PM
george6
Mark
99' D90 2.5L TD5
My steering box just started leaking.I've read many posts about whether to replace the seals or the whole unit.The majority favor replacing the whole box.Although,someone recommended zeus seals as a good cheapish quality long term solution.Has anyone used zeus seals ?
------ Follow up post added December 30th, 2010 02:10 AM ------
Hey Hans, the weather has turned against me now :-) I spoke about the snow earlier & here i am now in your thread with a leaking steering box :-(
Old December 29th, 2010, 09:18 PM
ajh
Andrew J. Hutton
Since you already have a LHD box (sadly I keep having to pay full as I have RHD boxes) use the rebuilder mentioned here repeatedly since apparently they use bearings vs bushings which should not wear oval like the originals and should not leak until the seals really do wear out.
Old December 29th, 2010, 09:30 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
+1 for the meridian boxes, been at least 2+ years no problems, course I don't do any offroading but lets face it, on a rover, if its last for 3-5+ years we consider that evidence of god being our co-pilot for those few years.
Robert Deniro
Old December 29th, 2010, 11:13 PM
Hans's Avatar
Hans
Hans Haase
Ironically, I haven't even ordered a new box for mine yet. I really should get it over with soon, I'm getting tired of topping off the fluid every couple of weeks. I'll get around to it eventually, but just don't want to do the work in the cold and snow.
-Hans
My oil line fix
Old December 30th, 2010, 06:47 AM
george6
Mark
99' D90 2.5L TD5
Mine needs urgent attention,she's leaking prefusely
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
steering wheel options Rick Carlisle Defender Technical Discussions 50 January 23rd, 2004 10:53 AM
