Steering box leaking - Page 2 - Defender Source
Old November 27th, 2012, 01:26 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
+1 for meridian. Be sure to get new high pressure lines, might as well.
Robert Deniro
Old November 27th, 2012, 02:14 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
Originally Posted by sherpamike View Post
If it's just seeping a little I would use Lucas stop leak and not worry about it.
I thought the Lucas products were more of a hail Mary solution. Heard that stop leak is a temporary fix and can clog up the rest of the system, causing more problems.
I dont know. Just what I heard.
Old November 27th, 2012, 02:36 PM
True for transmission, not a big deal on power steering. In any event, it is just a temp solution. The flaw with the rover steering boxes is that the use a bush on the lower output which wears allowing the seal to leak. Meridian replaces with a proper bearing.
Old November 27th, 2012, 02:38 PM
if you only have a few drops on the driveway pour some Lucas power steering stop leak in. In my case that has stopped leaks for months @ a time.
curry's Avatar
curry
brandon curry
Series 1 and 110.
Thanks.
Old November 27th, 2012, 04:22 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I am always a little leery of snake oil products... that said i've had success with lucas stop leak on small leaks.
Old November 27th, 2012, 04:26 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
It beats bubblegum I guess, right? I'll shoot for Lucas and see where that takes me. Then I'll order Meridian. Besides, what would an English car be that didn't leak some sort of fluid somewhere after all?
Old November 27th, 2012, 04:51 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
...what would an English car be that didn't leak some sort of fluid somewhere after all?
Exactly! As they say: you know it's empty if it doesn't leak!
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Steering box leaking.... options? Hans Defender Technical Discussions 17 December 30th, 2010 06:47 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
