Steering box leak - Defender Source
Old May 12th, 2013, 09:05 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Steering box leak
I have had this annoying steering box leak for months. A drip here a drip there. I finally got fed up and cleaned up everything and found the leak to be on the lowest point of the box (very accessible). Basically the shaft that connects to the steering arm/rod.
Has anybody successfully changed that gasket/bushing before. I am aware of meridian but if I can change this in place it would be much less labor intensive.
Thanks for the help.
Old May 12th, 2013, 11:01 PM
It won't last. There is a bushing in the box that wears which causes the play which causes the leak. Meridian replaces this with a bearing.
Old May 13th, 2013, 07:54 AM
tjfslaughter
thomas
Burbon
I read through this. It does not look that bad.
http://forums.lr4x4.com/index.php?showtopic=16765
Old May 13th, 2013, 08:02 AM
Removing the drop arm can be nasty. Really nasty.
Old May 13th, 2013, 08:55 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep, you can say that again.
http://www.defendersource.com/forum/...3&postcount=55
For the whole thread:
http://www.defendersource.com/forum/...ead.php?t=9482
Mike Hammond
Old May 13th, 2013, 10:40 AM
Maybe yours is a good canidate for some lucas stop leak. I drain my steering yearly add a pint of it and refill the rest with maxlife transmission fluid. All three Rovers under my supervision do not have leaking steering boxes. The hoses OTOH not so much.
Old May 13th, 2013, 11:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Harbor freight has a pitman arm puller that I used in conjuction with my impact hammer that just removed my stuck, frozen one off my RRC :http://www.harborfreight.com/tie-rod...html?hftref=cj If you use your 20% off coupon, it will run you a whopping $8. Best tool investment that I have made in a long time. I think the impact hammer made a big difference--it was off in under 1 minutes (after 2 days of trying other methods).
Old May 13th, 2013, 11:54 AM
tjfslaughter
thomas
Burbon
I have one of those. Worked great when I did the Tie Rod upgrade and ends. I am going to start with the stop leak first. I only leaves 1 drop over night (every night). When I slow down on this home renovation I will take a Saturday morning and pull the box.
Old May 13th, 2013, 11:56 AM
110Landy
Paul
1984 110 2.5D
I have the old steering box out of my 1984 110. It leaks, hence the replacement, but if you are interested I would sell it for a reasonable price and you could have it rebuilt and then do the swap. I figured I would rebuild it at some point so I would have a spare, but time is not cooperating.
Old May 14th, 2013, 08:22 AM
tjfslaughter
thomas
Burbon
Thanks for the suggestion. I put some in at lunch yesterday, last night I cleaned off the parts with brake cleaner and a pressure washer, and air dried it with the leaf blower.... No drips in the driveway last night or when I got to work this morning. There is a little seepage but not enough to make a drip. Thank you. This might have bought me a little time for a "planned sterring box service".
------ Follow up post added May 14th, 2013 08:23 AM ------
Thank you for the offer. At this time I am going to plan to change the box when I do the suspension later this summer.
Old January 22nd, 2014, 03:35 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I have the same issue, steering box leaking at his lower point.
How did you solve your leak ?
Anyone have a part number for the seal kit ?
Cheers
- Charles Eames
Old January 22nd, 2014, 04:11 PM
Seal kit is STC1042 or STC2848, BUT from my digging around the leak usually is due to internal wear. So, that said I opted NOT to replace my seal and just wait it out and see what happens. My leak actually appears to have slowed down or gone away, we'll see if that lasts.
Old January 22nd, 2014, 09:01 PM
tjfslaughter
thomas
Burbon
Same here. I used that stop leak and it slowed it. Tank is stays full for the most partI think I top it off about every 4 months. Steering box is always "moist" though.
Old January 22nd, 2014, 09:13 PM
You said "moist".
Old January 22nd, 2014, 10:53 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
You said "moist".
Duncan Hines Chocolate Cake Mix moist?
I wish I had one drip a night from my steering. I have to refill every week.
Old January 23rd, 2014, 07:30 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is where the plot thickens, 3 steering box model, 3 bolts, 4 bolts and 6 bolts.
wtf
- Charles Eames
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Steering Box leak cjbenway Defender Technical Discussions 3 February 26th, 2012 02:17 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
