Steering Box Adjustment tips? (Loosing nut) - Defender Source
Old July 12th, 2016, 04:47 PM
WestCoastRover's Avatar
2000 TD5
Cool Steering Box Adjustment tips? (Loosing nut)
There is some play in the steering wheel and it is in fact the steering box.
I have read posts about loosing the lock nut and adjusting the Allen bolt (slow increments) that is on top of the steering box. This eliminates the play.
My question is, on a LHD TD5 90, the locknut is very difficult to get a socket or 19mm wrench on.
Is there a specific tool or teqnique you can recommend to crack the nut?
I've had the hardest time and it's not brough up in other posts.
Also, some shops recommend not adjusting this as it is set from the factory, it's best to replace the box (but $$$, Plus I have read many successful adjustment stories)
Please advise
Thank you
Old July 12th, 2016, 05:47 PM
sflash868's Avatar
Stephan Laputka
1995 D-90 SW
Yeah I'm in the same boat. I have all new bushings and end links in the truck and it's still takes me swinging the wheel from 11 to 2 in order for the truck to go straight. I've also heard that the nut is set from the factory so I'd be curious to hear the response..
Old July 12th, 2016, 08:13 PM
I cracked mine loose then used an Allen to take out the slop. Too tight is bad but a Lil adjustment is fine.
Use a loooong extension on a LHD truck, RHD is easy... Took about 5 min
Old July 12th, 2016, 11:34 PM
bossman429's Avatar
Mine was RHD BUT ABSOLUTLY can be adjusted. Just leave a little slack as it will tighten up as components heat up
What feels perfect at rest may get stuck on you down the road a bit. And that's not fun. Basically get it perfect then back off a hair
Old July 13th, 2016, 10:58 AM
Viton's Avatar
Deaf Ember
Smart 4x4
For 175K miles, mine is pretty good, less than 12 to 1 O'clock play.
What really throws me off is the short wheel base and the Detroit locker.
The Detroit has a lot of play in it which makes the rear steer feel like there's more play in the front end than there actually is.
trouble accessing steering box adjustment screw on '88 D90 2.5TD ITALY2AMERICA Defender Technical Discussions 2 March 13th, 2016 04:21 PM
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 01:05 AM
Steering box replacement & adjustment 16kpsi Defender Technical Discussions 1 January 17th, 2011 05:38 PM
Steering box shaft movement after tightening pitman arm nut Neil McCauley Defender Technical Discussions 18 June 10th, 2008 01:18 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 07:31 PM
