Steering adaptor for Euro spec column? - Defender Source
Old November 27th, 2006, 10:52 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I am in the process of having my Series coiler changed over to power steering using the new style defender column which is a different spline than the NAS trucks. I have a Series wheel with a nice leather wrap and a Mountey 15" wheel which was on the old column. I'd like to use the Mountey if possible but need some help finding an adaptor for the new style euro column.
Old November 27th, 2006, 12:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kevin, check this out http://www.expeditionlandrover.info/PowerSteering.htm
Legend in My Own Mind.
Old November 27th, 2006, 03:03 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Thanks Randy, good article. The guts are all worked out, I just need a steering wheel.
Old November 27th, 2006, 05:00 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I'm sure you'll find an adaptor, but if you can't the guts (or inner shaft) of a Euro spec steering column can be easily swapped out for the guts of an NAS one. Its just the little roll pin at the bottom and the column's inner shaft slides out.
Email:
Old November 27th, 2006, 05:05 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I think I found the correct hub made by Mountney at Craddocks.
Steering column new or used CDeWan Wanted 2 September 17th, 2008 03:46 PM
95SW Steering wheel and Column SafariHP The Vendors Loft 2 May 18th, 2008 08:59 PM
Steering column refurbishment Muscat Defender Technical Discussions 0 February 19th, 2008 02:07 PM
steering column u-joint Noah Defender Technical Discussions 0 September 8th, 2004 07:04 PM
How to remove steering column? Chris Cox Defender Technical Discussions 6 October 22nd, 2003 07:24 PM
