Steel wheels - Defender Source
Old February 9th, 2012, 09:55 AM
Naplm00
Matthew
Steel wheels
Will these pro comps fit my early 110 with solid disc front and drum sals in the rear?
Any spacers required? ill be running 235/85-16
I would prefer my tires to be taller and skinnier so im assuming i should go with the 7in wide ver instead of the 8
http://www.procompusa.com/tools/filt...0&style=0&pg=1
http://www.performance4trucks.com/Wh..._pn=PCW87-6756
Old February 9th, 2012, 10:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Why not go a NATO/Wolf in a 6.5" width?
That would match up nicely with the 235 width of the tires and cosmetically be a much better match especially on an early 110.
Old February 9th, 2012, 10:53 AM
Naplm00
Matthew
Thats a great question, I really have no idea what they look like or the cost. Is there a part number i should look for?
Also my current wheels are Disco 1 spare wheels i think
these are what i have
Old February 9th, 2012, 11:05 AM
Naplm00
Matthew
yups, my issue when i bought the truck from Draaron he stated that it had just been painted. Well it had, except they didnt scuff or do any prep whatsoever on the wheels or body.
So now i have flaking paint all over the truck and wheels. Getting them powdercoated would be just almost as pricey as getting a new set of wheels it seems
I think i prefer the nato look...
it looks like the ANR4583 is the correct wheel, tubeless with 5.5 in backspacing is that correct?
Old February 9th, 2012, 11:25 AM
To answer the original question, the 16x7 should work fine. The only difference from your current wheels is they will sit out around 1" more outwards, which is a good thing.
Wolfs have around 4.5" BS, which is what you want.
http://rovers.red90.ca/roverwheels.html
Old February 9th, 2012, 11:29 AM
Naplm00
Matthew
all good info, Will the 6.5in wide wheels give my tires a taller profile compared to a 7 in rim?
Old February 9th, 2012, 11:53 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Are you asking, will the same 235 85 R16 tire on a .5" narrower rim result in an incrementally taller tire?
Not in a meaningful way.
1970 SIIA 88, Sold
Old February 9th, 2012, 11:55 AM
Naplm00
Matthew
Just what I needed to know. Its all about pricing now...and I'm cheap
Old February 9th, 2012, 12:04 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Don't know if the price is right, but this guy has them for sale
http://www.roversdownsouth.com/index.html
Old February 9th, 2012, 12:14 PM
I very much doubt you will find Wolf wheels anywhere near the ballpark as the Procomp wheels. WHOLESALE in the UK for a Wolf wheel is around $65....which is around full retail of the Procomp in the US.
Old February 9th, 2012, 01:14 PM
Naplm00
Matthew
Just to keep this thread informational i also found a wheel manufactured by black rock
http://www.polyperformance.com/shop/...l-p-25652.html
happens to be called the "defender" and is a simulated beadlock but it is a 15
Old February 9th, 2012, 01:40 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Load rated to 1200 lbs(?) v wolf @ 2200 kg (http://www.defendersource.com/forum/...p/t-14543.html)
1970 SIIA 88, Sold
Old February 9th, 2012, 01:57 PM
It says 1600 lbs for 15" and 2000 lbs for 16".
Click on the tabs below as they show a bunch of sizes including 16". Way overpriced though. You can get Allied Beadlocks in the price range.
http://www.high-impact.net/wheels/ca...land_rover.htm
Old February 9th, 2012, 02:00 PM
Naplm00
Matthew
ah I see it now, for some reason those tabs didn't appear in chrome
Old February 9th, 2012, 02:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
For a 235 those Wolfs/NATO's will work better like Red90 said. But they will be more $$$ than the Pro Comps.
I don't know how close you are to Atlantic British but they have these: http://www.roverparts.com/Parts/ANR4583PM.cfm You might be able to save some money driving up and getting them in person. I bought mine from AB years ago and AFAIK there are the real NATO wheels. Heavy as hell at 30+ lbs each but they seem to be strong and durable and have a good offset.
steel wheels, wheel, wheels
5 33x12.5x 15s BFG MTs on trek outfitters steel wheels draaronr For Sale - Parts 4 June 9th, 2005 09:06 PM
6 Steel Wheels 15x7 arbik For Sale - Parts 2 April 7th, 2005 11:41 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
Steel wheels! TwisteD90 Wanted 0 November 2nd, 2004 02:11 PM
Are you using stock alloys or steel wheels? dave_lucas Misc. Chit-Chat 3 October 3rd, 2004 03:56 AM
