Steel wheel runout and mud tire wear - Defender Source
Old January 9th, 2014, 02:41 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
All:
I'm currently running disco steelies on my 110 SW. Last time I was at the auto skills center I had the wheels balanced. The tech said that the wheels had a lot of runout, but he did the best he could balance them. Right now they look like they have a pound of weights each.
So now I've finally got some new KM2s on the way and will be mounting them in a month when I get home. I've done more reading about runout, and the web consensus is that it 'can' cause uneven tire wear or additional wear on steering/suspension components.
Does this apply to biggish (255) KM2s... and beefy LR suspensions and steering components? A lot of what is out there on the web is about average passenger vehicles. I know some folks say not to even bother trying to balance mud tires.
Thoughts? Is it worth it to get new wheels for my new tires? Keep running the ole' cheap steelies?
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 9th, 2014, 02:45 PM
You have to make sure they are balanced from the stud holes. Most places only cone balance from the centers and the centers are not machined on the steel wheels. You need to find a place that can balance from the stud holes or bring along a spare hub for them to use with the cone holder.
Old January 9th, 2014, 02:48 PM
ontheway's Avatar
ontheway
Dave
Interesting! Didn't think about that factor. Thanks
Old January 9th, 2014, 02:49 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Any reason not to go alloy? I used to be a big believer (and fan aesthetically) of steelies but have been happy with alloys for weight savings-nevermind that we did actually crack one catastrophically during VOT.
What I've noticed with my 255/85's is right out of the box on some decent alloys they balanced fine; which was good b/c the Ft Myer Auto Hobby Shop said they were too big to balance on their machine. Maybe Bragg has better equipment.
r-
Ray
Old January 9th, 2014, 02:57 PM
Beyond looks and off road durability, alloys do not fit onto the older Defenders without spacers or modifications to the wheels.
Old January 9th, 2014, 03:00 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Ah, didn't realize the fitment issues. Looks matter, durability I've found to be exceptionally relative for most applications.
r-
Ray
Old January 9th, 2014, 03:04 PM
ontheway's Avatar
ontheway
Dave
r-
Ray
BAHAHAHAHAHHA. You're funny.
Really though, I agree Alloys would be lighter and would balance better. For me its a matter of keeping the vehicle simple and 'no frills'. Plus, one day I'd like to be able to do events like VOT (2014 maybe?) and not worry about wheel failure. From the pictures though it looks like I'll shred 4 tire sidewalls before I crack a wheel.
Old January 9th, 2014, 03:11 PM
Ray_G's Avatar
Ray_G
Ray Gerber
For VOT run 255's on steelies (so you can beat them back into shape if need be) and carry two spares + tire kit with extra plugs...
It's a blast
Old January 9th, 2014, 03:15 PM
has anyone ever had an aluminum Rover wheel fail?
Old January 9th, 2014, 03:19 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I tried to have a set of black steelies balanced using the stud holes but could never find a shop in Florida that had the adapter for the 5x6.5 bolt pattern.
Old January 9th, 2014, 03:22 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Yes. my 1st post referenced mine at VOT after a rock in a water crossing cracked it. Prior to that I had the same view; we're not in Africa-its not likely to happen. It still isn't...but it definitely can. I still run alloys mind you.
Old January 9th, 2014, 03:25 PM
jafir's Avatar
jafir
Jafir Elkurd
I've read the Deep Dish wheels had failures on Discos at Camel Trophy:
http://www.valmueller.net/camel-trop...g-information/
My D1 had tornadoes and I couldn't get them to fail no matter how hard I tried.
Of course I wasn't trying as hard as the Camel Trophy drivers.
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's a blast
Definitely two spares. I found out quickly that 255/85s are not a common size around southern Vermont(or northern)
Old January 9th, 2014, 03:52 PM
Best to pick up a used hub from someone.
Old January 9th, 2014, 04:07 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I have 315/75/16 BFG KM2's on stock Deep Dish Alloys. No weights. I used 8oz of the premium one piece AirSoft pellets in each tire. They purr like a kitten going down the road and no vibes.
Old January 9th, 2014, 04:44 PM
Ray_G's Avatar
Ray_G
Ray Gerber
For the sake of the VOT component, and the amusement at seeing it again:
Nice and broken
Sourcing a replacement spare from DAP left me with this gem
VT is hard on tires...
Old January 9th, 2014, 04:45 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Truth. Could be worse, Roudy had a hell of a time getting the Excursion road worthy to come back to VA.
Old January 9th, 2014, 05:32 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
What I am talking about is called a flange plate adaptor that goes on a balancing machine so the tire can be balanced using the stud holes rather than the center hole. I could not find a shop that had one that would fit the Defender bolt pattern. http://www.haweka.com/en/index.php?nav=5.79.83.103
Old January 9th, 2014, 07:01 PM
I know. What I'm saying is if you get a used hub they can put it into any normal balancer and bolt the wheel on. This works well and you can go anywhere.
Old January 9th, 2014, 07:08 PM
that an impressive dent
mud, tire, wheel
