Steel wheel runout and mud tire wear - Page 2 - Defender Source
Old January 9th, 2014, 07:14 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by rover4x4 View Post
that an impressive dent
Wife was driving...
...but I was telling her to speed up. It was on me
Old January 9th, 2014, 07:45 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
It made a great fire ring!
When I first got my 110 it was on steel wheels. I got a set of alloys so the steel ones could be refinished. I never had an issue balancing the steel wheels. Of course I am running the skinny stock tires. Thanks for the hub tip.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old January 9th, 2014, 09:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I had a shop and we specialized on balancing on exotic and off road exotic. It is true that a steel wheel can have a larger run out than a alloy wheel. You will have a high spot in the wheel and a high spot in the tire. If both of these spots are together then you will get a hop in the fitment and an unbalanced tire. If you were to spin the tire 180 degrees and mis-match the high spots you may completely take care of the problem. This is called tire matching. The higher the rubber content, like a mud tire, this effect can be exaggerated. Certain tires are known for not being too round adding to a possible problem. Some steel wheels are hub centric and can be properly balanced by using the center cone method. Most after market steel wheels are not. Defender alloys are hub centric. Balancing by the studs is not the best way if you have a hub centric wheel and flange. Just as trying to center cone balance a wheel that is not hub centric. One way to help get around all of this is get the tire balanced on a "road force Balance machine" Not every shop has these as they are very expensive. It is indeed very hard to find a shop where the installers actually know what they are doing. Looks like it may be a lost art. Or at least an art that is getting lost.
Old January 9th, 2014, 09:25 PM
I ran a nato/wolf wheel with a bit of run out with 285 KM2 on it. Tire blew eventually @ highway speed on DC beltway. Wheels are cheep, my advice would be get good/true ones.
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Originally Posted by Red90 View Post
I know. What I'm saying is if you get a used hub they can put it into any normal balancer and bolt the wheel on. This works well and you can go anywhere.
Gotcha!
Old January 9th, 2014, 10:38 PM
ArlowCT's Avatar
ArlowCT
Ryan Lowe
1973ish SER III, 88"
Im running custom narrowed disco 1 steelies with 235/85 KM2's. 8oz of BB's in each tire and they run perfect. Plus don't have to worry about knocking weights off in the rocks!
Old January 10th, 2014, 04:38 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Wow, thats all I needed to hear Doug. Thanks, dave
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
mud, tire, wheel
