STC8358HD heavy duty clutch kit - Defender Source
Old September 26th, 2011, 04:35 PM
Naplm00
Matthew
Anyone know where I can get a kit like this? I think it comes stock on the 130s and the commercial version of defenders.
Is there also a good source for the HD clutch fork?
When i putting in the engine i figured I can swap in a new clutch and release fork. 20tdi lt77 setup
saw them here and talked about on landy zone
http://www.mm-4x4.com/3-piece-heavy-...tdi-2658-p.asp
Old September 26th, 2011, 05:28 PM
I think Doug just got one for his unfortunate 130. At least that's what he showed me and Dave. It's nothing more than a regular clutch fork that has a flat plate welded on the back to keep the pivot ball from punching thru.
The RRC/Disco I 200 Tdi release fork is cast.
Old September 26th, 2011, 05:33 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The only " heavy duty" piece is the friction plate. which is a 130" one.
was part no. FTC1994, but now superceded to UQB000130
Cover plate and thrust bearing are all the same.
Old September 26th, 2011, 08:35 PM
Naplm00
Matthew
Worth the extra coin?
Old September 26th, 2011, 08:39 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Here's one place:
http://www.mailorder4x4.com/acatalog...utch_Kits.html
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 26th, 2011, 10:05 PM
Probably not.
Old September 27th, 2011, 02:49 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I used to run with one in my old Tdi 90. although I never managed to break a standard clutch in that, i suppose for extra peace of mind it's worth it.
There's not much extra difference between them. slightly different cushion springs in the center bit, and the overall diamater is a bit bigger. Think i measured it to 5mm or so. but work out the extra surface area of 5mm, and it was something like 35mm2, so i suppose it'll help if you're heavily loaded or have a tweeked engine.
Old September 27th, 2011, 06:13 AM
I just broke the clutch fork. It was the only part in there I re-used. I am running the HD clutch plate as called for in a 130. The clutch fork allowed the pivot point to push right through the fork. This despite no sign of wear last year and a generouse dab of synthetic grease on re-assembly. My advice would be to put new everything in there. I would definately go with the HD clutch fork. I got a kit from Eric @ Atlantic British for $30. Ne clutch fork,plastic retainer staple, and pivot pads as well as a new "spigot bush".
Old September 27th, 2011, 06:56 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I love it when you talk dirty.........
Matt Browne
clutch, kit
heavy duty air to coil kit P38 kjva Misc. Chit-Chat 2 July 28th, 2011 06:23 AM
Heavy Duty OME & the works Rover- Girl Wanted 1 January 30th, 2006 09:21 AM
Heavy Duty Front Bumper david_jackson Wanted 2 January 5th, 2005 07:07 PM
Bearmach Springs Heavy Duty... h2eater For Sale - Parts 0 July 9th, 2004 12:40 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
