Station Wagon 90 110 Sliding Rear Window Fixing Thread - Page 2 - Defender Source
Old November 30th, 2009, 12:17 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Jim.
This is really helpful.
Old December 1st, 2009, 11:36 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Jim,
Any special trick to removing the rubber gasket around the exterior of the windows?
Old December 1st, 2009, 12:50 PM
The one that hides the rivets? The trick is to grab and pull. Putting it back is where the problem is, but again, no special trick, just windex and dexterity.
Old December 7th, 2009, 08:56 AM
I'm putting together a Christmas gift list for my 90 and need to do the felts ... does anyone have part numbers?
My windows rattle but seem to slide ok?
should I do more than felts?
Old December 7th, 2009, 09:22 AM
Felts should be OK. I just ordered some from LRseries.com, the number wasn't quite right because they were too short. They were close enough, so I used them, but you'll want to figure out the correct number. It might be MUC3096, but that might be too short also. Not sure.
Old December 9th, 2009, 12:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
rear sliding window 110
Why the F is one of my rear sliding windows rattling when I drive? It is closed and doesnt move when I touch it but when I get up to speed it sounds like crap.
Old December 9th, 2009, 12:37 PM
Because the felts are worn out or missing.
Old December 9th, 2009, 12:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
can I get them easily. hate is growing
Old December 9th, 2009, 12:52 PM
I rolled up a little ball of electrical tape and slit it between the windows, it helped a lot.
Old December 9th, 2009, 12:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
not a terrible idea. I guess I can't open it then. What about using Hay?
Old December 9th, 2009, 01:32 PM
I think between this and that spider that kept making its webs all over the 110, it's time to just give up and sell it.
Old December 9th, 2009, 01:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
you are right. let the next owner deal with the rattle
Old December 9th, 2009, 05:02 PM
Barry, the search function can be used for terms other than "boost wheels"
Old December 9th, 2009, 05:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why search when I can start a new exact same thread
I clicked your link and nothing came up
Old December 9th, 2009, 05:15 PM
That's because I was busy merging this thread with the old one.
Old December 9th, 2009, 05:20 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
This is what I do too. fold electrical tape over 3-4 time to make it about 1/4 inch long. then fold it in half 1/8 and use a flat head screw driver and stick it up between the windows.
or after doing some electrical work, take those little 10-12 gauge pieces you snipped off and stick those in there.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 9th, 2009, 05:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah no way i want to drill the rivets out for the felt. Electrical tape and horse hair it is
Old December 9th, 2009, 05:29 PM
So who's got the part #s for the felt and track?
Old December 11th, 2009, 07:04 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I used thin strips of black foamcore doubled up between the glass on the outside like a shim.
Can be removed easily to open windows when needed.
(I have sliding windows on my fiberglass hardtop)
Old January 30th, 2013, 09:58 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
sliding window re-fitting
I'm attempting to re-install my left rear sliding window after installing a Garrison Outfitters window rubber kit. When it came out I sort of had to pry it, but just by hand. Now that I'm trying to get it back in, it doesn't look anywhere close to fitting. With the bottom part in, it looks like I need another 2mm of clearance to get it to fit.
ANyone deal with something like this? Any advice? I'm baffled.
------ Follow up post added January 30th, 2013 09:59 PM ------
I'm aware that I'm adding to an old-ass thread)
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
110, 90, window
90 rear mudflaps on a 110 ... Retrofit Defender Technical Discussions 0 May 16th, 2009 06:21 PM
Defender 110 Station Wagon Seatbelts Shearpin Smaller Projects 8 October 24th, 2007 05:01 PM
Rear sliding windows? dmarchand Defender Technical Discussions 11 January 24th, 2006 01:37 PM
110 Rear Light Assembly Ron Thompson Wanted 0 August 22nd, 2005 02:13 PM
Rear ST window bar mpodgorski For Sale - Parts 4 July 27th, 2004 12:03 PM
