Starts and Cuts Off Immediately - Defender Source
Old December 8th, 2009, 10:01 PM
tdn's Avatar
tdn
Troy Norton
'94 D90
Not sure if this is just coincidence but 94 D90 stalled on me while sitting at red light. Was running low on gas so I figured I ran it dry. Put a few gallons in it and.....no start. Well, actually it seems to start, but then cuts off immediately. I can even get it to rev very briefly if my foots on the peddle as I'm starting it but it immediately cuts off. After checking fuses and a few things I found it'll run if I hold the key in the start position. I can even drive with it that way. As soon as I let off the spring load on the key, it cuts off. So I was thinking....bad ignition switch?
start
