Starting with or without... - Defender Source
Old August 25th, 2010, 09:13 AM
jijalicious
Jiman Khosravan
'94 D90
Question Starting with or without...
On your D....
When you want to turn on the engine when it's in neutral... which one is you:
1) Turn key, engine turns on
2) Press in clutch, turn key, engine turns on
~J
Old August 25th, 2010, 10:10 AM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
If I'm in the drivers seat: #2
If I'm standing outside the truck I'll physically confirm it's in neutral then #1
Old August 25th, 2010, 12:52 PM
jijalicious
Jiman Khosravan
'94 D90
The reason for the question...
Friends of mine who drive stick shift (infiniti and hondas) are saying you should HAVE to push the clutch to turn on the engine, Neutral or Not.. and they're saying something must be wrong with my 90 if I can turn the car on (while in neutral) but without pressing on the clutch.
Old August 25th, 2010, 12:55 PM
Grover's Avatar
Grover
Nothing wrong with your D90. It's deisgned to start in gear for wheel'n purposes...
Cheers...
Old August 25th, 2010, 01:12 PM
dchapman
Daniel Chapman
1999 D1
Many trucks have a clutch safety switch that can be bypassed by pressing a button. Toyota for example. Older cars and trucks may not even have this option at all and the vehicle can be started without having the clutch pressed in. More newer cars and trucks do have this, though.
The safety switch is designed so that no one accidentally jumps into a vehicle with a manual transmission, turns the key, and have the vehicle lurching into something....like another car or building.
Nothing wrong with your Defender. It just has one less part to fail.
Old August 25th, 2010, 01:57 PM
jijalicious
Jiman Khosravan
'94 D90
Old August 25th, 2010, 02:42 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
If i'm sat in it, i usually press the clutch in. defenders don't have a safety cut-out on them, but for me it's force of habit for safetys sake, and from tractor driving where most ones you need to clutch-in to start, and my sisters kawazaki 500 bike you need to pull the clutch in too.
Also (but to a lesser extent), having the clutch in saves the starter a slight bit of extra load, i.e. not having to spin some of the gears in the 'box, especially if it's cold and the oil is thick.
Old August 25th, 2010, 02:51 PM
Get in car. Grab stickshift and wiggle to confirm in neutral. Turn key. No pressing the clutch until after it starts. I do this in all my cars AND I always use the ebrake so when I do screw it up and try to start in gear, it just stalls out rather than lurching forward.
Ron
Old August 25th, 2010, 03:04 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
One disadvantage of starting with the clutch depressed is that it tends to exert a forward force on the rear main thrust bearing while there little oil pressure.
Old August 26th, 2010, 09:05 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
These friends of yours are the ones that all of the safety and warning labels are made for.
LOL Exactly!
Same here.
Having ever only owned manuals, I sometimes even try to depress the clutch in my wife's ZF D1.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 26th, 2010, 09:56 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hum, never even thought of that. Is that really a concern? Never heard this one before. Is that specific to LR/Buick/Jag V8 engines or across the board?
On diesel engines, I depress the clutch to help the engine start. On gasoline engines, I do it when the battery is low or when it's cold(ish) outside, and seldomly at any other times.
My father (my reference probably for my entire life) taught me those things, they are probably derived from tractor experience/life.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 26th, 2010, 10:04 AM
Ron
or pulls your neighbors hedge out. Did that bush live ?
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
Help With Starting My D90! Davis Defender Technical Discussions 0 September 7th, 2004 05:13 PM
