Starting Problem - Defender Source
Old December 14th, 2012, 06:54 PM
CDeWan
Clay DeWan
5.3L beastie
Starting Problem
I am sure someone has addressed this but I breifly search through the forum. Here goes: If I leave my key turned all the way on but don't start it for a period of time - let's say 5 minutes - it won't start. I can smell gas out of the exhaust pipe and I pulled a plug wire to see if it is getting spark and it is.
Me thinks - the fuel pump runs while I have the key on and too much fuel ends up in the combustioning chamber - if that is the case then I have leaky injectors?
Anyone - I think to test that I should leave the key on for spell, turn it off and start pulling plugs and see if I can find the cylinders with significant gas smell?
Or just maybe I am on crack and this is a common problem with a quick fix - such as a fuel temp sending unit on the fritz or...
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
Intermittent Starting Problem 61rover Defender Technical Discussions 0 September 24th, 2010 01:50 PM
Hot starting problem that won't go away. lostindecoland Defender Technical Discussions 8 February 27th, 2010 10:53 PM
Interesting starting problem kolvedic Defender Technical Discussions 3 December 12th, 2008 06:12 PM
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
