Starting Issues with my D90 2.5td - Defender Source
Old March 3rd, 2013, 10:23 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
Angry Starting Issues with my D90 2.5td
Hello, I've been having problems starting my D90 for 2 days and now my rig is simply not starting. It took a while starting 2 days ago and when it did start everything was fine until I tried to restart it. I had to jump the battery and then It started with trouble. My metre gauge read 12v. I then had the alternator rebuilt and fitted on Saturday and took the battery to the shop to have it fully charged. Now my starter is giving me trouble. I have to knock the starter due to sticky brushes in the starter. I've also noticed that there was no current going to the glow plugs. I jumped the glow plugs and the truck is still not turning over. Tomorrow, I will have the starter rebuilt and sought for a new glow plug relay. Am I missing anything? Does anyone have any ideas? Thanks
Old March 5th, 2013, 10:11 AM
couga861900
Any advise?
Old March 5th, 2013, 10:54 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Have you check your grounds? Do you have a draw on the battery?
Mods please move this to technical section.
Old March 5th, 2013, 01:00 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Moved.
Old March 5th, 2013, 03:58 PM
navydevildoc
Neill Thornton
When you are saying "it's starting with trouble" do you mean it's turning over slowly, or that it's turning over fine and just not firing?
Old March 6th, 2013, 11:24 PM
couga861900
Well, I've noticed that there's no current going to the glow plugs. I've therefore concluded that the starter is, stressed out.
Old March 7th, 2013, 07:19 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Is the Defender sitting outside in the cold? A cold start on a diesel can be difficult. Getting the glow plugs fixed is a good start. I would also check each plug as they seem to go bad easily. I would then check the CCA on the battery. It can be reading the correct voltage but the CCA can be down. The Diesels do need a lot of CCA in the cold.
Land Rover 110
Old March 7th, 2013, 10:13 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If your battery is not rely strong it will make for a really difficult start
Legend in My Own Mind.
Old March 8th, 2013, 11:23 AM
couga861900
Thanks guys. I'm going to get a new starter and get a cold start relay and make sure that current is going to all the glow plugs. I think I'll need a schematic for the relay and plugs. I will have to fully charge both batteries too.
Old March 8th, 2013, 01:07 PM
Ben01
Ben
Defender
Try a new battery and get an engine block heater.
Old March 9th, 2013, 05:03 AM
12v at the battery is a problem. You should have 13 plus. Its sounds like you have several problems. Fix the glow plugs and the starter and then figure out the battery or charging issue.
Old March 20th, 2013, 12:20 AM
couga861900
turning on the truck
Good advice. I change the starter and read other forms. I've just learnt that I was not starting my truck properly. I've had the truck since June it seems that I did warm the glow plugs. I've learned the following:
1- when you put the key in it's in the off position.
2- next turn to the left is another position which I thought warmed the glow plug but it does not
3- a slight turn more before turning the truck (you have to hold the key at the spring-like position) is the warming of the glow plugs. At this position, the glow plug light will light up on the dash
4- count to 15 or 30 and turn the ignition to the on position.
5- there's no relay for the 2.5 or 2.5td model. The glow plugs connects to the ignition switch. The 200tdi and 300tdi have the timer relay on the engine side of the bulkhead.
I was starting the truck w/o using the glow plugs and burning/wearing out my starter.
Now I have a rebuilt alternator, fairly new battery, and a new starter but my volt gauge/metre is only reading 12v. I think I should be at 13v or 14v. Any clues anyone?
Old March 20th, 2013, 12:31 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
ck the alternator output at the positive terminal of the alternator itself and at the battery should be at least 13.5 if not it was rebuilt wrong
No Mall crawler here
Old March 20th, 2013, 12:39 AM
couga861900
In the morning I will do so. I was wishing/hoping that I would not have to take out the alternator again and walk 1 mile to the rebuilder again. Thanks a lot.
90, d90, start, starting
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
considering d90 toolman Misc. Chit-Chat 7 March 28th, 2005 02:36 PM
