Starting issues - what to check - Defender Source
Old February 17th, 2014, 10:35 AM
dlbriller
Doug
1987 ex-MOD 'Tithonus' Defender 110
My 2.5 NA has just this morning developed some issues turning over. When I turn the ignition key (after letting the glow plugs glow for at least 20 seconds) the engine makes a quick attempt at turning over with a small puff of black smoke, before giving up and then the starter motor just spins. All of the electrical connections appear to be in good shape, the battery is fully charged. Any suggestions on what else to check?
Old February 17th, 2014, 11:00 AM
Could it be flooding the cylinders?
Old February 17th, 2014, 11:18 AM
How cold is it? Your fuel could be jelled.
Have you cleaned out the sedimentor and replaces the fuel filter recently?
Old February 17th, 2014, 11:25 AM
dlbriller
Doug
It started up and ran fine twice yesterday, so I'm guessing it's not a significant fuel issue. It's about 25 degrees here now and I've run it in cold weather before.
Old February 17th, 2014, 12:06 PM
dlbriller
Doug
We're up and running again, may have been a bad fuel/temp issue after all. We'll see what happens on the road.
Old February 17th, 2014, 01:35 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Get some of PS 911 at just about any store and add it to your current fuel.
Then I use the PS Supplement from November thru March.
and run the PS Kleen the rest of the year
I have had fuel Gel issues randomly at different cold temps and look at it as Cheap Insurance. Just my $0.02
ID:	89851   Click image for larger version
Name:	PSD suplament.jpg
Name:	PS Kleen.jpeg
start, starting
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
How to check fuel pressure? Heath Defender Technical Discussions 3 January 11th, 2005 02:28 PM
Just an FYI on starting & fueling issues Doug Defender Technical Discussions 1 November 4th, 2004 05:34 PM
d-90 on Ebay...check it out! boshea Misc. Chit-Chat 5 October 31st, 2003 02:55 PM
