Starting issues warm engine 200tdi - Defender Source
Old November 29th, 2015, 06:01 PM
Mes788
Mike S
110
I am on the road and heading back down to naples and just started noticing an issue with my 200tdi. If I shut off my engine and restart it within 1min it will not start. I need to let it sit for a few minutes and then it starts right up. I am wondering where I should start with my troubleshooting in the morning. Any suggestions would be appreciated....
Mike S.
Naples, FL.
Old November 29th, 2015, 06:04 PM
BlackField's Avatar
BlackField
Oscar
D110
Does it fail to crank, or cranks but will not start?
Old November 29th, 2015, 06:26 PM
Mes788
Mike S
110
It cranks with plenty of power. Full battery also
Mike S.
Naples, FL.
Old November 29th, 2015, 06:41 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Check the nuts on the injectors, make sure they are all tight. Return lines too
Old November 29th, 2015, 07:08 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
sounds electrical. I wonder if the fuel solenoid is craping out. if you cycle power on, do you hear it click in the <1minute of shut off?
Old November 30th, 2015, 02:00 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
If its cranking and not catching the solenoid is likely. Make sure the connection is tight.... and buy a spare just in case.
Old November 30th, 2015, 02:09 PM
I'd change the fuel filter and the fuel solenoid. They are both cheap.
Old November 30th, 2015, 02:25 PM
D90user's Avatar
D90user
steve
FWIW- I keep a spare fuel solenoid in all my tdi's. Cheap insurance for something that can leave you completely stranded if it decides to fail.
Not that they fail often, but its the only piece of electrical equipment that can strand a tdi.
Old November 30th, 2015, 02:42 PM
great tip
Old November 30th, 2015, 02:45 PM
In an emergency, you just pull the guts. Not really much reason to carry a spare, IMO.
Old November 30th, 2015, 02:51 PM
D90user's Avatar
D90user
steve
Unless you want to turn the truck off!
I was really referring to 'bush' spares. For DD duty no need of course.
Old November 30th, 2015, 02:58 PM
You just stall it. Not complicated. 15 years of expedition wheeling almost exclusively with diesel Defenders, I have not seen one fail. Not really at the top of my spares to carry list.
Old November 30th, 2015, 03:06 PM
D90user's Avatar
D90user
steve
I had one fail!
It was on the way from San Pedro, Chile to Tuzgle, Argentina in the altiplano at ~15,000ft. It was having intermittent starting issues and I thought it was altitude. One day, it wouldn't start. It took a while to figure out and it was the solenoid. I was glad I had one and I have one in the truck all the time now.... but I have a ton of spares.
Old November 30th, 2015, 10:52 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It takes up no space whatsoever. Better to have it and not need it that to need it and not have it.
200tdi, engine, start, starting, tdi
200tdi with Low Oil Pressure once warm seeks advise. PNW110 Defender Technical Discussions 13 October 7th, 2015 09:18 PM
Warm starting issues Grover Defender Technical Discussions 10 September 20th, 2015 02:18 PM
D90 2.5l Petrol hard to start with warm engine. 89Defender90 Defender Technical Discussions 19 May 13th, 2015 02:49 PM
Flood Condition when engine warm 97-D90-736 Defender Technical Discussions 0 December 3rd, 2010 03:27 PM
Just an FYI on starting & fueling issues Doug Defender Technical Discussions 1 November 4th, 2004 05:34 PM
