Starting issues - Slow Start After Truck Warms - Page 2 - Defender Source
Old May 19th, 2015, 06:06 PM
Update #2... Battery tested out ok, problem was the ignition module, 2nd bad new one
95' D90 - daily driver..
Old May 20th, 2015, 11:19 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
My thought at present time - replacing coolant temp sensor did not correct the issue.
My next replacement is - replace ignition module.
My truck has the relocation kit but I will replace the module anyway.
Any thoughts?
Weldon
Old May 21st, 2015, 02:10 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
!Help!
I see a wide range of cost for the ignition module - from $16.00 to over $200.00.
What should I do - not looking to break the bank or pay over $200.00 if it is not needed.
Plus I do not want to create any more headaches with a sh** part.
Weldon
Old May 21st, 2015, 02:41 PM
Originally Posted by Weldon View Post
!Help!
Borrow one ... and see if it makes a difference.
If it doesn't then you don't need to replace yours.
Old May 21st, 2015, 03:04 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
No access to a loaner/one to barrow.
Is there a cross reference on a cheap one that can be had at AutoZone or the likes of?
Weldon
Old May 21st, 2015, 10:24 PM
I went through 2 bad ones from ab.. About $90.. (Replacement was and hopefully will be free)
Old September 13th, 2015, 05:18 PM
Grover's Avatar
Grover
Question
Any updates of this? Mine sh!t the bed twice today on a warm start...
Old May 13th, 2016, 11:34 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Sorry for the sllllooow reply to this thread.
Wanted to give a bit of time - test in warm weather and test in cool to cold weather.
Still have the same issue - when truck is cold - truck starts right up - starts on the first crank.
I can have the truck sit for weeks - truck starts on the first crank - in cold to hot weather.
If weather is cool to cold and I drive the truck - stop and go by means of turning truck off then back on - no issues.
If weather is warm to hot - truck struggles to crank after it's warmed up and stop and go by means of turning off and then back on - truck struggles to crank and in some cases it needs to sit to cool off for it to crank.
HELP!?!
Weldon
Old May 16th, 2016, 09:00 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
I'm sure others have experienced this issue - shit is killing me to figure out.
Weldon
Old May 16th, 2016, 09:06 AM
couple of things to look at..
1) timing should be set within reasonable factory limits - the manual calls for 5 degrees, last one i checked was at 20 degrees advanced which was way too much...
2) hot start issues can be also caused by an over heating starter.. so check the cables to it from the battery, make sure your not blowing exhaust on to it, and that its secured in there..
since it only does this when cold, this leads me to lean to overheating starter scenario as the primary culprit.
but could also be other electrical stuff... the chicklet, the ignition module, etc.
Old May 16th, 2016, 08:20 PM
carlosz's Avatar
carlosz
Carlos
starter perhaps..?
Old May 19th, 2016, 01:51 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks.
Ordered a starter and will report back.
Weldon
Old July 25th, 2016, 04:11 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
Weldon- Did your new starter fix this for you? and when replacing - did you install a new heat shield?
I have a '95 4.2L that is doing this to me at the moment as well.
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old July 28th, 2016, 08:49 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Any update on starter resolving you're issue?
Do, or do not, there is no try!
start, starting
Starting issues - Truck wont Fire/Catch (Wet?) sad_story Defender Technical Discussions 63 November 15th, 2015 11:04 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Oil pressure drops when engine warms up flananuts Defender Technical Discussions 19 September 7th, 2011 12:12 PM
NAS 110 Slow starting! Architect Defender Technical Discussions 2 June 16th, 2010 04:10 PM
NAS 110 slow to start- help wanted Architect Defender Technical Discussions 6 February 5th, 2009 08:40 AM
