Starting issue - Defender Source
Old August 18th, 2013, 11:58 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Starting issue
Once I get it started she runs great, but the issue is - sometimes not all times when I turn the key there is a delay or the starter does not spin. I am thinking it is a short or the ignition switch. Has anyone experienced this? Does anyone have a part number for the ignition switch for an 83 110 v8 rhd.
1983 ROW D110
1970 Series III (Parting out)
Old August 19th, 2013, 12:28 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Check your battery and the cable running to the trigger on the starter.
Jimmy Buffett
Old August 19th, 2013, 03:35 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Part is 551508.
I think you are correct in assuming it's the ignition switch.
Cheers
Jay
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Hard starting, everything else fine? Doug Defender Technical Discussions 16 July 11th, 2004 01:25 PM
