Starting 200tdi Engine Removed from truck - Defender Source
Old June 29th, 2016, 08:32 AM
richord
Richard Ordowich
1987/D90
I have just completed preparing my Discovery 200Tdi to replace my 2.5TD. I would like to test the engine before installing it in the truck.
Besides the 12V to the starter and the glow plug, and the cutoff wire are there any other electrical connections I need?
I need to feed it fuel and connect the spill rail. Any other fuel connections I need?
Can I start the engine for a quick run 1-2 minutes without putting any coolant in? I want to avoid having to connect the radiator although I will have to connect the oil cooler lines.
Any other considerations for testing?
Thanks.
"Slow down and smell the diesel"
Old June 29th, 2016, 08:56 AM
Check that the oil level is correct.
IMHO I wouldn't recommend running any air-cooled engine without coolant, although if you do, then at least fill the block with coolant (water) until it spills out the radiator hose, and shunt the radiator hoses if you can. A minute is a long time.
Old June 29th, 2016, 08:57 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Rent my
Naplm00
Matthew
Yea I wouldn't run it for more than a min, and I would fill it with coolant and loop the lines
Old June 29th, 2016, 09:53 AM
Just keep in mind that a lot of the time, you need to put load on the engine to get the cylinder temperatures up well enough to all fire depending on condition and how it was left. In other words, a short cold idle does not tell you much about condition.
Old June 29th, 2016, 10:06 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We often run engines for 6 or 8 hours before draining the fluids and shipping them, but we use a run in stand that has mounts positioned in the same location as the frame mounts for the series LRs.
If you are going to go to the trouble to run the engine, I guess the real question is what do you intend to accomplish by running it?
In other words do you have a checklist of things like oil pressure, temp, compression, and so on.
It is smart that you want to run the engine because most people, just drop a well used engine in and hope for the best, while experiencing the worst.
Suggest you take a compression check and replace the rear main seal, timing belt, head gasket, water pump, fuel pump, front housing seal, thermostat, have the injectors checked or install reman ones.
Then you could hook up the radiator and intercooler and give it a proper run before you install it.
With the turbo disconnected from the inlet manifold, your engine will be somewhat over fueled and under pressurized, which will not give any indication of how well it runs. So it's best to run with the Turbo connected to the intake, preferred via the intercooler.
Also if you decide to run it make sure you use clean fuel and disconnect the injector lines and flush out the trash before starting, so your injectors don't clog with accumulated trash.
Also read John's post because running an engine on a stand or on the ground is very different from experiencing how it reacts under load.
RDavisinVA
Old June 29th, 2016, 05:31 PM
richord
Richard Ordowich
1987/D90
Thanks guys. I changed the timing belt even though the one on the engine was in great shape. Installed new rear oil seal, relocated the alternator to the right side, replaced the thermostat, clocked the turbo and cleaned the engine.
I just wanted to run it up before installation. I will setup the new radiator and fill it with coolant, oil and run it for a longer time. I will check the compression beforehand.
200tdi, engine, start, starting, tdi
Starting issues warm engine 200tdi Mes788 Defender Technical Discussions 13 November 30th, 2015 10:52 PM
Rover 300tdi engine R380 5-speed kit, removed from Discovery ZombieMotors For Sale - Parts 1 April 26th, 2013 05:35 AM
Proper 1988 Defender petrol V8 engine, runs great& complete. removed for turbo-diesel ZombieMotors For Sale - Parts 0 April 1st, 2013 12:17 PM
2001 Discovery 2 engine & transmission for sale- Removed for TD5 conversion ZombieMotors For Sale - Parts 2 February 28th, 2013 11:13 AM
Rear seats removed - to plug or not? pmd Defender Technical Discussions 9 April 12th, 2006 03:13 PM
