Starter Wiring - Defender Source
Old April 7th, 2008, 01:47 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Starter Wiring
So I had a mean green starter and after two of them failing on me I have decided to switch back to a stock starter. The one I ordered has a bolt where the majority of the wires go, but then has two tabs. I have one skinny black wire that I am sure goes to one of the two tabs, but I am not sure which one. Any ideas?
The only way to differentiate from the tabs on the start is that one is narrow and one is wide.
Thanks for any help.
B
Old April 7th, 2008, 07:05 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Trigger wire goes to the tab on the top. Think its the skinnier of the two. Good to see I'm not the only one with bad luck with the MG starters.
Jimmy Buffett
Old April 7th, 2008, 09:45 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias. Ya the MG starter gear exploded once and then on the replacement just died altogether after 6 months.
B
start, starter, wiring
'83 starter motor wiring / relay? turbodave Defender Technical Discussions 1 November 16th, 2008 10:40 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Can't remember starter wiring Heath Defender Technical Discussions 5 February 15th, 2004 10:59 PM
