Starter went out? - Defender Source
Old January 9th, 2014, 09:18 AM
molonlabedoc
Vincent
1987 D90
Starter went out?
Couple of days of really cold weather (for Kansas) and my starter had to work pretty hard to get the truck to turn over. I will be getting a warmer.
Anyways last night I put the key in, turned over and heard a clicking near the dash (close to the relay box) and a electronic wirrring noise.
Should I pull the starter and get it tested?
Thanks for any intel.
Old January 9th, 2014, 09:21 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Sounds like a weak battery or failing ground.
RDavisinVA
Old January 9th, 2014, 09:22 AM
both of which burn up starters
Old January 9th, 2014, 12:14 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
That clicking near the dash is your solenoid not having enough juice to run the starter. Change your battery or jump start it.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 9th, 2014, 01:22 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Get a Kat's battery (electric) warmer blanket. Check your starter connections and bat(-) connection to frame. Cleaned your bat terminals lately ?
Old January 9th, 2014, 02:58 PM
molonlabedoc
Vincent
1987 D90
Thanks for the help guys, I know its prob some obvious stuff but I will pay it forward
Old January 9th, 2014, 03:38 PM
molonlabedoc
Vincent
1987 D90
I have a double battery set up (bosch). I have never charged a system like this, is there a trick to it?
Old January 9th, 2014, 07:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It all depends on how they are wired.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 13th, 2014, 04:48 PM
molonlabedoc
Vincent
1987 D90
So I was looking in my battery box under seat. There is a random unbolted blue wire. Is that the ground for starter?
ID:	87824   Click image for larger version
Old January 13th, 2014, 04:54 PM
Starter is grounded through mating w engine block. Make sure your block ground strap is in good condition. And that blue wire is ghetto. Get rid of it.
Mark Kellgren
KM4BOR
Old January 13th, 2014, 05:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you are asking these sort of questions, you need to take a basic auto mechanics course at the local community college or find a way to educate yourself on the subject.
In the mean time find a local who knows about cars and try hooking up jumper cables to start your rig (commonly known as jumping).
Then buy yourself some Land Rover manuals and some tools if you don't already have them and start reading and doing a few small jobs like hooking up jumper cables.
If wires are disconnected, don't connect them.
Hope this helps.
RDavisinVA
Old January 19th, 2014, 06:30 PM
molonlabedoc
Vincent
1987 D90
So the batteries are good, The starter was bad, replaced it. BUT, it still makes an electrical whirrr noise and nothing turns over after replacing old starter.
What should I look for next? Thanks for any ideas.
Old January 19th, 2014, 07:51 PM
I think you need to clarify what you mean by "electric whirr".
Is the engine turning over? Or is the starter spinning but not engaging the flywheel?
Old January 19th, 2014, 09:57 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Mine crapped the bed yesterday as well. You can hear the starter motor spin up but the solenoid isn't engaging the gear, to crank the motor over.
Mine sounds like this one at the 3:30 mark in the video.
I know cheesy video.
Unknown Author
716-898-8153
Old January 19th, 2014, 10:37 PM
the solenoid on a starter does not engage the flywheel. What engages the flywheel is a device internal to the starter that pushes the starter drive gear out.
Old January 19th, 2014, 11:37 PM
molonlabedoc
Vincent
1987 D90
Turns out to be a bad wire from the battery. Fires right up.
Thanks for the info everyone.
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
