Starter switch broke, now what? - Defender Source
Old October 17th, 2007, 01:00 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Fun night tonight leaving work. Go to start the truck, and "SNAP" something gives way inside the ignition switch.
Key turns, but doesn't do anything at all. Electrical is stuck in the "ON" position, steering wheel is unlocked, but engine didn't crank long enough to start. I suspect the link between the tumbler and the actual switch mechanism is what gave out.
About 10 minutes of throwing dash parts in the back, and I have it hotwired and on the way home. Yanked the feed wire off the switch to shut it down.
This gets me to the "Now What?" part, for tomorrow morning. The book, of course, will show me how to rebuild a component like the starter but has nothing whatsoever about the starter switch other than a wiring diagram. So where do I look, and what am I expecting to find?
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 17th, 2007, 01:23 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
My guess is that yours broke like mine did. When you opened the column was the back half of the switch just loose in there dangling from the wires? Anyway, I don't think there is much you can do aside from buying a new switch. It isn't that exp. and takes about 1 beer to install (including putting the column housing back).
Old October 17th, 2007, 02:28 AM
Hans's Avatar
Hans
Hans Haase
actually, the whole housing appeared to be intact. Seemed to be an internal failure.
Will know more tomorrow.
-Hans
My oil line fix
Old October 17th, 2007, 05:28 AM
RDS sells the one without the bing bing bing wire for cheap. NAS is $$$.
Old October 17th, 2007, 02:30 PM
Hans's Avatar
Hans
Hans Haase
Got it apart, snapped apart inside the column lock portion, and I just don't have the tooling to make the new component and re-assemble it all. Looks like I need the whole assembly. What a pain in the ass to get it off the column too, had those security bolts that the heads snap off of, so I had to drill the bolts out. Fun Fun Fun!
Good news is that I have it all temporarily rigged up to drive until I get around to that. Horray.
-Hans
My oil line fix
Old December 4th, 2007, 03:30 PM
Hans's Avatar
Hans
Hans Haase
Ok. Finally got my new lock assembly via slowboat shipping. Went in fine. Just want to confirm that I have the wiring on the back properly. Everything functions properly, but just being paranoid. For some reason the spot on the switch I am using as the input has two tabs on it, this seems odd to me and the old one didn't have any double-tabbed terminals on it.
Anybody have a chart that says which item goes to which numbered terminal on the back of the switch?
My oil line fix
start, starter, switch
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
