Starter replacement mishap - Defender Source
Old May 25th, 2007, 11:48 PM
bjenk
Brian Jenkinson
1994 D90
I read up on all the previous post concerning replacing my starter (94). Crap!!!! I went out and purchased the hex socket and had the bp blaster, but I still ended up stripping out the top bolt. I was lucky enough to get the bottom bolt out after using a propane torch to heat it (it was semi strip as well).
I ended up cutting off the top bolt head and was able to get it started out using vice grip, but then it locked up and would not budge. I have blasted it with bp and nothing. So, I decided to drill it out. All was going well when drill bid broke off inside the bolt. I am so screwd right now that I am besides myself. The only other option I see is dropping the tranny and getting to the back side of the bolt.
Any other suggestions???
How hard is it to remove and install tranny?
2 bolts that was all I was trying to remove and now I am deep into it. I just can't believe it. My plan now, unless someone has a brilliant idea, is to remove the tranny, drill bolt from back end and then extract or use a longer bolt with nut.
brian
Old May 26th, 2007, 09:01 AM
Damn, big hassle. Lets see a pic. Have you used the vicegrips to just wiggle the bolt a bit? Some times going back and forth in the threads will get things started, then you can do more work with the PB blaster.
Old May 26th, 2007, 12:32 PM
bjenk
Brian Jenkinson
1994 D90
I will take a picture asap. But I have to get my other truck running now and pray that it will work.
ac, start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
