Starter replacement - Defender Source
Old July 11th, 2014, 03:57 PM
Dragon Breath's Avatar
Dragon Breath
Jay
Blank
Starter replacement
It seems I have a bad solenoid b/c I've had to tap the starter every now and then to get the D90 to fire up. Unfortunately I on't have time to replace my starter right now so asked my local guy what it would run and he had this to say:
"Starter motor replacement is $570.48 out the door. That is a remanufactured Bosch starter which is OE equipment. Cheaper starter motors can be obtained from most auto parts stores, but my experience with them has been very negative. Either you don't get the right starter, the starter doesn't work
when you install it, or it fails within a few months. I use Bosch units with great success."
I love my local LR guy and use him on most stuff that is beyond me, but this is a starter.... If this is one of those things that I could have done at a regular shop at lower cost I think I'd go that route.
Thoughts on whether I really need to go with a remanufactured Bosch and whether I really need to go to someone who works on about a dozen local Defenders?
Old July 11th, 2014, 04:07 PM
The cheap starters are $135-$150. While I have no idea what your guys labor rate is, if you have ever replaced a rover v8 starter it can go ok or it can go horribly. O2beatsea here on the site recently chronicled how he was able to get the lower bolt out but not the top and used a jack to bend the starter until it broke off so he could get better access to the top bolt. The bolts are allen headed and tend to strip out before reaching the torque that will break them loose if they weren't installed with antiseize (which the factory didn't do). I replace the bolts with regular hex headed bolts when I do one, operating from the assumption that I'll likely be the next person to put a wrench on them.
Old July 11th, 2014, 04:36 PM
You can sometimes more easily access the top bolt by removing a spark plug wire or two on that side of the engine and trying to tackle it from above. I went with Magnetti Marelli for mine and it's been great. Most starters won't hold up long being submerged in muddy sand etc. if you're offroading a bunch with it, but should otherwise be pretty good.
Old July 11th, 2014, 08:51 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I just replaced my starter with a remanufactured Bosch, and did the work myself. Now for the shocker: I paid $90.00 for mine exchange, in Southern California and it took me about an hour and a half to swap the starter. Keep in mind, I'm no mechanic but just a little handy like most on this board. It's a straight forward job in tight quarters, and I didn't have to remove a single spark plug either. Not trying to contradict rijosho, that was simply how I did mine on a 3.5L V8.
Now to the starter: I was simply googling starter rebuilders in my area and came across this shop that rebuilds all kind of electric parts with a bunch of positive reviews. I called and they had it on the shelf and gave me a 1 year warranty with it.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 11th, 2014, 09:47 PM
Your truck is a bit easier being a carburated 3.5 with simple downpipe as opposed to the later catalytic converter fuel injected trucks.
Old July 11th, 2014, 10:06 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You need to clean the Allen screws VERY well. Get in there with a pick, brake cleaner, compressed air, etc. Use a QUALITY hex bit. Craftsman or better should be fine. Once the bit is in there tap it with a small hammer or whatever to "seat" it.
As mentioned, replace with a regular hex cap screw.
Old July 14th, 2014, 01:42 PM
Dragon Breath
Jay
Blank
Thanks -- the remanufactured Bosch is supposed to run me $350 and $190 in labor.
Old July 14th, 2014, 02:01 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I would get under there and see if you can get the bolts loose first, if not then take it in. I think you're gonna kick yourself if you paid $190 in labor for something that can be done at home.
MUDSUX
Old July 14th, 2014, 02:07 PM
That's the labor rate for them to remove and replace the two bolts of the starter?
Old July 14th, 2014, 02:51 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Why not get a lifetime warranty gear reduction starter and save $125 and have a better starter? Install it yourself and save another $190.
http://www.britishstarters.com/Land_Rover.html
Old July 14th, 2014, 03:13 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Free Shipping to boot
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 14th, 2014, 03:19 PM
Thats the suggested retail for a bosch reman but they typically sell for considerably less.
Here's a site that list many co's remans and their prices. You can save $100 right out of the gate and I'm thinking you can find a bosch quite a bit cheaper. Prices for remans start @ $89 and go up from there
http://www.autopartswarehouse.com/sh...discovery.html
Old July 14th, 2014, 03:31 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I'm a cheap bastard, my last two starters have cost me $65 total. I have 3 D1's and 2 spare starters. :D
Old July 14th, 2014, 04:13 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I personally think it's insane to be paying $350 for a remanufactured starter, even if it's a Bosch. Like others have said on here, you can buy one for under $100 with a one year warranty, or spend a bit more and get Lifetime Warranty on one.
Thank you - Samer
2003 Discovery II
Old July 14th, 2014, 08:46 PM
i was recently looking at the starter on my favorite LWB IIRC i removed the starter with ease when it (engine) was out of the truck. I had no drama with hex bolts etc. I am somewhat regretful that I reused the original allen bolts having read this. If you keep the front driveshaft lubed the starter should have a plenty of grease on it.
ac, start, starter
200TDi Starter Replacement BlackField Defender Technical Discussions 24 July 15th, 2017 09:27 PM
Starter replacement mishap bjenk Defender Technical Discussions 2 May 26th, 2007 12:32 PM
Starter Problems Trigger Defender Technical Discussions 10 September 27th, 2006 10:00 AM
Can't remember starter wiring Heath Defender Technical Discussions 5 February 15th, 2004 10:59 PM
how much should I pay for a starter Campbell Defender Technical Discussions 5 November 4th, 2003 02:38 PM
