starter removal - Defender Source
Old July 13th, 2011, 11:36 AM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
starter removal
I thought I would pull the starter and clean it up have it tested and replace if necessary. I can see the lower bolt that is holding the starter in place, but can't seem to get to the upper bolt? I tried from the top and from the bottom and can't seem to even feel around and locate it. RAVE doesn't seem very helpful with the "remove starter motor" entry.
Just wondering if there is something I need to remove before I can get to this bolt or is there something I am missing?
thanks,
Bill
Old July 13th, 2011, 12:10 PM
Bill, read the following from a few weeks back.
http://www.defendersource.com/forum/...ad.php?t=31762
You can try unplugging the two spark plug leads in the middle passenger side and stick your hand through there and put the hex and 6" extension on the bolt. Then climb under the tuck and hook the ratchet to it and undo it that way.
Old July 13th, 2011, 12:45 PM
kolvedic's Avatar
kolvedic
Bill Lewis
dude! you rock. My search-fu is weak.
Bill
Old July 13th, 2011, 12:46 PM
Eat your Wheaties before trying to remove the top one, as mine was pretty stuck.
Old July 15th, 2011, 08:53 AM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I'm a little late to the party but...
Once you have your hex bit and extension and ratchet wrench all set up, grab a pry bar and fit it through the manifold. You should be able to pry against the head ratchet wrench with enough force to keep the hex bit from slipping in the terribly placed bolt.
Should your starter bite the dust AND you can't get said bolt out, take the bottom (easily accessible) bolt out, and use a big chisel and a pry bar from the bottom. With a little grunt work (just think about how upset you are that the top one is stripped out!) you can crack the top ear off the starter and take the starter out. With it off the engine, you should be able to spin the top bolt out with a pair of vise-grips.
Old July 15th, 2011, 09:37 AM
kolvedic's Avatar
kolvedic
Bill Lewis
Thanks for the advice. I have tried a few times to get the 8mm in the top bolt with no luck getting it to seat in the hex top. I tried cleaning it out but still no luck. I haven't really had the time to play with it a lot but will give it all a try this weekend.
It is in a sort of bad location, but I had an old buick that the first step was 'remove the engine' to get the starter out so I am pretty happy. that thing took a lot of hammer blows over the years.
Bill
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
» Defender Registry
Runt
speedpin
D-Storm
LI90
Add your Defender
