Starter Problem? - Defender Source
Old April 7th, 2013, 05:47 PM
Firstgeer
1996 Disco 1
Starter Problem?
Hi,
I am a complete novice. My 1985 ex military Defender isnt starting.
I have ruled out the battery and the starter is getting 12v. It almost turns over but never really gets it done.
Any suggests on where I should look next?
Thank you for you help
Old April 7th, 2013, 05:56 PM
Gas or diesel?
Old April 7th, 2013, 06:07 PM
Firstgeer
1996 Disco 1
Originally Posted by Rocky View Post
Gas or diesel?
diesel
Old April 7th, 2013, 06:41 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Have you tried jumping it? Just because your battery is showing 12v doesn't necessarily mean the battery is getting the amps needed to really crank.
Semper Fi!
Old April 7th, 2013, 07:13 PM
Firstgeer
1996 Disco 1
Yes, sir.
I had my disco hooked up to her with industrial cables and the same results.
Cha cha cha kr cha cha cha
Old April 9th, 2013, 07:53 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Try connecting the jumper cables, from a battery that actually starts a car, to the pos terminal on the starter and one of the mounting bolts, then jumper to the solenoid. If it doesn't crank then, it's likely the starter.
If does crank, then you have wiring problems between the battery and starter, either in the pos circuit, or the earth.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 9th, 2013, 09:13 AM
Firstgeer
1996 Disco 1
I will try jumping it directly when I get home tonight.
Long story short, between her running and now (2 weeks) I think someone might have tried to start her up cold. Would trying to start her cold, without giving the heating plugs an opportunity, cause damage after a few attempts? If so, where should I look.
Thank you for the help!
Old April 13th, 2013, 07:01 PM
Firstgeer
1996 Disco 1
Here is a recording of what she sounds like when I try to start her.
Jump to :20
Old April 13th, 2013, 08:07 PM
CDN d90's Avatar
CDN d90
mathias
94.5 d90 NAS CDN #10
I would Jump it for sure as it sounds the battery is not putting out enough juice.
And if it is not starting then it could be the solenoid is acting up a little.
good luck
If you have one do not complain about gas prices.
Old April 14th, 2013, 08:52 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Not necessarily. Depends on how long they tried. Excessive cranking can overheat and damage a starter. But you'd have to crank a good length of time. I've put a dead vehicle in 1st and cranked it in gear to move it off the road, without damage.
Continuing to crank when it will barely turn over is a lot more likely to damage a starter.
To clarify my previous post, I meant if you know for a fact the battery is good. You don't say how/why you've ruled out the battery.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 14th, 2013, 12:19 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
good luck
He already tried jumping it. This clearly sounds like lack of power to me, you can hear the solenoid clicking on and off due to lack of "umph".
I would double check the ground straps between the battery and the chassis, and the chassis and the engine. If one of them comes loose, you don't get good power to the starter.
If you jump it directly to the starter and it works fine, then ground is what you look at next.
Old April 15th, 2013, 08:51 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Right. But bad cables and/or connections can eventually kill a good battery. It's a reasonable start, but isn't conclusive proof. I've been burned too many times by making assumptions. Otherwise I agree, that's why I suggested bypassing the Rover wiring entirely to rule out the starter, or not.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 15th, 2013, 09:48 AM
Firstgeer
1996 Disco 1
Thank you everyone for all the help!
I was able to isolate the problem as a bad ground. When I grounded the starter directly to the negative terminal on the battery with the jumper cable, she would start right up. I went back and re-cleaned all the grounds. She is now starting like a champ.
Thank you again!
start, starter
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
