Starter Motor - Defender Source
Old June 27th, 2013, 09:32 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Starter Motor
Hey guys, starter motor has officially gone on the 90... had to hit it everytime to get the 90 started yesterday so ordered a new one last night. Question is for those who have replaced one on a 300tdi, is it easiest to take the panel off and access through the side?
thanks in advance
Old June 27th, 2013, 10:22 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No...
thanks in advance
No. You should be able to get it out from underneath and snake it around the down pipe.
RDavisinVA
Old June 27th, 2013, 10:59 AM
Wear eye protection when you're under the truck!
Old June 27th, 2013, 11:25 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Awesome thanks guys, should save sometime not having to take the body pannel off and I'll make sure to have some good old eye protectors on.
Old June 27th, 2013, 11:56 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Didn't your starter fail months ago???
Old June 27th, 2013, 02:13 PM
USLandy's Avatar
USLandy
Andrew
defender 90
It failed almost exactly 1 year ago and did the old smack it trick and got it working. From then I hadn't had any problems with it since then untill yesterday, and it now needs to be hit everytime to get it going so it is going to be replaced. Ordered the part from Trevor at rovahfarm except he hasn't got any instock right now so may be replacing sometime next week.
Old June 27th, 2013, 02:26 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Sounds like you milked it pretty well.
Are the 90 starters secured with those stupid socket cap bolts like the D1's are?
Old June 27th, 2013, 02:38 PM
It should last more than a year. Was it a Britpart brand starter?
Old June 27th, 2013, 02:50 PM
I dont think he replaced it a year ago. He started hitting it a year ago, and has limped it along/made it work for a year.
-jeff
I reread the post. 1 year of smacking it around. Not bad!
Old June 27th, 2013, 03:59 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Yeap, just to confirm it was 1 year of giving it a good little knock with the end of a breaker bar
Old June 27th, 2013, 04:35 PM
So can you take the old one to an armature shop to get rebuilt?
motor, starter
2.5NA Starter Motor Issues Michael110 Defender Technical Discussions 3 February 24th, 2014 12:54 PM
'83 starter motor wiring / relay? turbodave Defender Technical Discussions 1 November 16th, 2008 10:40 AM
Rebuild kit for starter motor ini88 Defender Technical Discussions 1 May 23rd, 2008 04:50 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
