Starter ground to engine - Defender Source
Old July 11th, 2016, 09:24 AM
seaswood
Diesel
The starter I removed from the engine 2.5 diesel has a bridge on the front for the ground wire to the engine. Ground attaches in the center of this bridge, Paris Rhone starter. The replacement starter has the bolts nuts on the front but does not have the bridge & the one from the Paris starter does not fit, I could drill it but it is right where there is a bend.
I got the replacement starter from someone on here that does not have this bridge on the front? Remanufactured in Israel, looks good otherwise.
Is it necessary? Starter of the left is Paris Rhone the bridge is between the two.
& does anyone know where to get a starter rebuilt Paris Rhone
Old July 11th, 2016, 09:27 AM
Ground to any of the motor securing bolts/studs is fine.
Old July 11th, 2016, 09:46 AM
Naplm00
M
I think I made a ground cable for mine and just used one of the nuts/studs, tossed the bridge thing
Old July 11th, 2016, 10:23 AM
seaswood
Diesel
Ground cable
Anyone know where to get a starter rebuilt?
it was starting sometimes first time sometimes third time some play in the shaft.
Old July 11th, 2016, 11:09 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Had the same issue and I ran a ground from one of the mounting bolts to the chassis. Fine for 3+ years.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 11th, 2016, 11:15 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Starter is bolted to the engine and engine is grounded.
Why is/was there ever a need for a separate starter ground?
RDavisinVA
Old July 11th, 2016, 11:43 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Excellent point, wondered the same when I replaced my starter.....wonder why LR seemed to do it? My thinking is given the amperage involved, a direct path to chassis ground is a good idea.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 11th, 2016, 12:15 PM
seaswood
Diesel
Paris Rhone
The Paris Rhone starter removed was XMod so assume of better quality.
Supposedly a radio truck maybe why or it was the spec?
I was also cleaning around a motorcycle starter, it also had an attachment point on the front, ground to engine.
Old July 11th, 2016, 12:35 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Designed no doubt by someone who wears a belt and suspenders.
RDavisinVA
engine, start, starter
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 09:04 PM
ground up build advice needed. mountainviewrover Misc. Chit-Chat 16 November 8th, 2007 07:28 PM
ground strap mattdh Defender Technical Discussions 5 November 25th, 2006 03:35 PM
D90 Ground Problem? cdnpaul Defender Technical Discussions 0 December 4th, 2003 02:36 PM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 03:01 PM
