Starter going bad? - Defender Source
Old September 14th, 2004, 10:14 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Starter going bad?
What are the signs of a deteriorating starter? Mine intermittently starts slowly. It sometimes turns over slowly, in the same way as when your battery is low on a charge. But at other times, it starts up just fine.
Could this be the starter or the sign of something else?
Old September 14th, 2004, 10:37 PM
I would start with the battery since they are cheaper than a starter...... other than I got no idea sorry
Old September 15th, 2004, 04:17 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
If the battery and cables/grounds are OK, then yes it sounds like the starter/solenoid is going south. One day it won't start.
Old September 15th, 2004, 04:08 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Also could be the heat shield is gone and the starter is HOT. this has happened with my cuda.
Old September 15th, 2004, 04:43 PM
loykd's Avatar
loykd
Ken Loy
I'll have to take another look at the battery cables, but I think they're all ok. Battery is a Yellow Top Optima, only 2 years old I believe, and I haven't thought it would be the cause.
Ron, there doesn't seem to be rhyme or reason to why it happens. Sometimes it's when the engine is cold, sometimes it's when it's hot.
Appreciate the thoughts. Any others?
Old September 15th, 2004, 05:13 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I had the same problem. Replaced my starter with one a friend had rebuilt and have had no issues.
Jimmy Buffett
Old September 15th, 2004, 10:12 PM
Ahh Ken! Don't you remeber our first trip to Paragon? My strter died, it was making horribal noises. Check the connections like said, measure the battery voltage (should be above 12 volts), you could also measure the voltage at the starter to make sure it is gettin full voltage.
start, starter
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter gone bad KeithD Defender Technical Discussions 3 September 16th, 2004 09:34 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
