Starter failed - Defender Source
Old November 29th, 2014, 01:04 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Starter failed
Starter failed on the truck (V8/4.0). Build date was june 1997
The mean green that was on it had 11 teeth and the one I'm about to put in only has 9 teeth (oem spec)
Any thoughts on if the 9 would make a difference. The engine has never been out of the rig, so I assume the flywheel is the same.
Old November 29th, 2014, 01:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mean Green uses the cheapest made in China units that they sell for maximum mark up.
The reason for the 11 tooth is the starter pinion gear is not on center.
By moving it to one side, the higher number of teeth mesh properly, but are not as close to the ring gear as the 9 tooth pinion gear which is on center.
Both should work fine.
RDavisinVA
Old November 29th, 2014, 01:34 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Thanks. Knew neither of those things about the Mean Green. It came on the truck. Didn't expect it to fail though.
Old December 1st, 2014, 07:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
My experience is that Mean Green products don't last.
RDavisinVA
start, starter
FAILED Maryland Emissions test Flagg Defender Technical Discussions 47 April 22nd, 2015 03:27 PM
Failed Emissions! Defender_90 Defender Technical Discussions 16 May 2nd, 2012 03:32 AM
Emissions – failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Tail lights Failed and I got arrested!! RickM Defender Technical Discussions 8 April 21st, 2008 06:02 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
