Starter Bolts (Chev) - Defender Source
Old April 1st, 2016, 06:45 PM
RamblerRob
Rob Apps
1967 series 2a 109 NADA
Not a rover specific question but it plays into my current rover project so here goes.
My project requires a GM 153t flywheel and my chev 4.3 block doesn't have the required straight across holes. No problem I picked up a starter from CSR performace that comes with an adapter block to correct the problem. ( http://www.summitracing.com/int/part...0sbp/overview/ )
Seems like my block uses 4.5"(+/-) x M10 coarse bolts whereas my starter came with 3/8th -16 bolts. They are longer than stock to accomodate the starter block and the shank is narrower as the stock bolts cant go through the holes. they are also un-knurled. The 3/8th bolts DO thread into the m10 holes but they bottom out about a quarter inch short of being tight. My stock bolts have about 1/4 inch at the tip where they are unthreaded.
I'm not sure on the best coarse of action here. Two things jump to mind.
1. Should I get the starter mounting block hole bored out and notched to accept the stock bolt?
2. or should I grind away the threads on the starter bolt for the 1st quarter inch to give it room to seat properly.
There is also the matter of the narrower shank diameter just above the threaded portion.
Can I some how sleeve the unthreaded portion of the hole in the engine block to make sure the bolt fits tight without any wiggle room at the shank? Or is that not something to concern myself with at all?
Old April 1st, 2016, 09:13 PM
Um I'd get the proper bolts, yup, I would.
Old April 1st, 2016, 09:15 PM
RamblerRob
Rob Apps
the good news is that I have the propper bolts.. they are just too short. I dont think they make the right girth at the right length. So should i get the mounting block notched and bored out to take the stock bolt?
Old April 1st, 2016, 09:41 PM
no idea what you are doing but it sounds way wrong.
bolts, start, starter
Late model chev v6 to ZF4hp22 RamblerRob Smaller Projects 15 September 27th, 2016 04:05 AM
Chev 4 cyl ecotec engine RamblerRob Series Technical Discussions 2 January 4th, 2015 07:02 AM
Starter Problems Trigger Defender Technical Discussions 10 September 27th, 2006 10:00 AM
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
how much should I pay for a starter Campbell Defender Technical Discussions 5 November 4th, 2003 02:38 PM
