starter bolts - Defender Source
Old November 1st, 2005, 11:14 AM
jstrong98's Avatar
jstrong98
Jon Strong
starter bolts
My starter went out on friday night, and saturday I began the process of replacing. Well, after a few hours saturday we could only get the bottom bolt loose. I searched the board before we started to get some "insight" on the project. The posts I found listed the size of the bolts as an 8 mm hex key. Used with a 3/8 ratchet and extension. The top bolt was so tight, I actually rounded off the 8mm hex key major PITA. Soaked it with PB blaster all nite, got a new 8 mm hex key, and broke the top bolt loose the next day.
Well, turns out these bolts are actually 5/16". The 8mm will do it, but I believe it is just .001 smaller, and when there really stuck this could make for a rounded off bolt. The threads are SAE also.
Just wanted to post this for anyone who may replace a starter in the future.
JS
bolts, start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
