Standard vs. Metric Brake Line? - Defender Source
Old July 17th, 2010, 12:33 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Refresher: I'm replacing the short line between the flex line and the caliper on the front passenger side brakes. It has a bubble flare on one side, and an inverted flare on the other. I have both fittings.
Need some clarification on the brake line/pipe - What makes a brake line metric? The tube? The Flaring? or just the fitting?
Long story, but my friend's flaring kit's 3/16 adapter for inverted flares is missing, but he has some standard brake line with and inverted flare on one end, and the tool to make a bubble flare on the other.
Before we did this, I wanted to make sure that the 3/16 line and the inverted flare are universal as long as I use my metric fittings.
Hope that's a clear question
Jerod
Old July 17th, 2010, 02:40 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
3/16" works perfectly. I just redid my entire truck in 3/16" with metric fittings and so far no leaks or issues. Just make sure you make the proper double inverted flare - which you need that 3/16" adapter to make properly.
Semper Fi!
Old July 17th, 2010, 04:23 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Sweet. Thanks for the validation.
Old July 19th, 2010, 03:11 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Even though I live in the US I have to say in my opinion the thread title wrong - it's "standard or Imperial units". Metric is pretty universal outside this country for some silly reason. Where do I have to go to sign the metric petition?
I have recently gone through the annoying quest for metric fittings... surprising, considering the number of Asian and European cars here (and the fact so many US car parts are shipped metric) maybe the auto parts stores would carry a few more metric fasteners.... sigh...
Old July 19th, 2010, 05:43 AM
Wolf Fabrication
Sterling Archer
'08 D3
So true! When I did my truck I drove all over town looking for fittings. I ended up having to use a few adapters just to make thinks work.
Semper Fi!
Old July 19th, 2010, 12:26 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
There are two issues.
Rigid brake lines - 4.75mm is the stock size.
3/16" is fine. For our purposes it's the same size. 4.75mm=0.1870" -- 3/16=0.1875"
Brake line fittings - Yes, you need metric.
If you can't get them locally, I've heard nothing but good things about Fedhill for fittings.
For people who also own series Rovers, they have the British thread fittings for them as well.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 19th, 2010, 12:28 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Sorry - wasn't trying to create an international incident
I just wanted to be clear and get a quick answer. I dig the metric system!
I did use metric fittings, it was the lines and the flares I was curious about. All seems to fit well. We'll really find out when I get the whole system juiced up and bled later this week..
Old July 19th, 2010, 05:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Then you're good, provided you didn't bodge the flares.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
brake
Brake line upgrades - what/where to buy? pmd Defender Technical Discussions 11 March 30th, 2007 11:58 PM
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Brake Line whistler110 Defender Technical Discussions 2 November 25th, 2006 08:18 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
brake line connections artm Defender Technical Discussions 0 May 7th, 2004 02:04 PM
