standard rear door tire carrier - Defender Source
Old August 24th, 2011, 03:54 PM
300 TDI
ken
D90
I was wondering if anyone knows if a 285 width tire will fit on a standard rear door tire carrier? The rim has a 11mm offset if that makes a difference. Thank you for any info
Old August 24th, 2011, 04:50 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
With my 265/75/R16 BFG AT's I had to get a bit clever with how I tightened the lugs in order for the wiper to work. I'm not sure my rim offset though (I have these wheels -> http://www.automotix.net/images/prod.../aly72143u.jpg ). If you're using the same wheels as I, and have a rear wiper, I don't think it'll work. However If you didn't need the 2-3" of clearance for the wiper arm, it probably will.
hope that helps
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 24th, 2011, 05:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have helped put a 285 on a NAS rear door. No issue if you adjust the washers and lugs behind it.
I would be afraid of the weight on the door though
Old August 24th, 2011, 10:38 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Not sure about your rim "offset" but a 285 will fit on the rear door. It's not as easy getting to the door handle and they're pretty heavy. As mentioned above you will need to move backing nuts further away from the door.
carrier, door, rear door, tire, tire carrier
Rear Tire Carrier The Wizard Defender Technical Discussions 15 January 6th, 2006 11:29 AM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Rear Tire Carrier Joe P Wanted 1 February 15th, 2005 06:45 PM
D90 SW rear wheel carrier mdmccallum Defender Technical Discussions 14 January 27th, 2004 02:45 PM
