Stalling when wet - Defender Source
Old March 3rd, 2013, 08:20 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Stalling when wet
Quick question on behalf of someone new to Rovers. This friend of mine says his 90 stalls and sputters when he's off road and crossing water. First question was depth of water which he says less than a foot. But he says he's moving through it quickly so it splashes pretty good.
I've never experienced this before and im fresh out of ideas. He is 5 hours away so I can't see what's happening.
Clay
Old March 3rd, 2013, 08:54 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
bad ignition wires? cap/rotor......just a guess .. tell him to go out there at night with a spray bottle .. with the truck running spray the wires and watch the light show ...
No Mall crawler here
Old March 3rd, 2013, 08:55 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
What year 90? I had similar problems and it was the ignition module
Old March 3rd, 2013, 09:01 AM
1of40's Avatar
1of40
1of40
Pretty sure it's got 94 with square lights in the back.
Great idea re spray bottle. I'll suggest he do that and utube it.
Old March 3rd, 2013, 09:12 AM
Replace the spark plug wires and encourage him to register here if that doesn't solve the issue.
Another part of the solution is not trying to look like a speedboat when he goes through puddles.
Old March 3rd, 2013, 09:23 AM
Could've gotten coil connections wet, mine does this when I wash it.
Old March 4th, 2013, 07:41 AM
1of40's Avatar
1of40
1of40
I think so. He's going to start with new wires and move from there.
Thanks guys.
Old March 4th, 2013, 08:00 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Clay, for what it's worth, with quality (i.e., all aftermarket) wires, dizzy, and coil, the engine runs fine with a carwash wand spraying directly on and soaking these parts.
Old May 1st, 2013, 03:35 PM
Did he ever figure out what the issue was?
Old May 1st, 2013, 06:44 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
The LH shock cover was missing. Hit a puddle and it would soak the coil, module, etc. I reproduced the issue easily by spraying water in the wheelwell with the truck idling- once water hit the coil wire it would stall instantly.
rear seal is wet jblieb Defender Technical Discussions 5 September 14th, 2005 10:01 AM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
stalling and sputtering roverboy Defender Technical Discussions 7 November 4th, 2004 04:19 PM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
Why is my D90 stalling? JRowe Defender Technical Discussions 4 November 10th, 2003 04:17 PM
