Stalling problem HELP - Defender Source
Old February 7th, 2007, 08:52 AM
esprit99's Avatar
esprit99
Keith Imbriglio
1997 D90 SW Arles Blue
I'm wondering if anyone has any input on a stalling problem with a 1997 D90 4.0 engine, all stock accept a snorkel. The truck starts and runs fine untill full warm up; After full warm up, if the truck is in park/nutural it will stall. Having the truck in drive will keep the idle up just enough to prevent stalling. While the engine is warming up the idle is 900 RPM, normal and fine, when warm and in gear 600/650 RPM and on the edge of stalling, when warm and in park the truck stalls. It seems to me to be a sensor problem. No check engine lights. Any thoughts?
Life is to short to drive ugly cars
'97 D90 SW #2251 Arles blue
'16 RRE
'04 Disco
Old February 7th, 2007, 09:29 AM
Chaucer
Will
93 110 | 97 90
I had that problem...Ran a can of BG 44k through half a tank of gas - cleaned everything up.
Old February 7th, 2007, 09:37 AM
esprit99's Avatar
esprit99
Keith Imbriglio
Sorry for the ignorance but what is that.
'16 RRE
'04 Disco
Old February 7th, 2007, 10:28 AM
Chaucer
Will
93 110 | 97 90
It's a fuel system cleaner...cleans your injectors. I think the problem you might have is carbon build-up. It's expensive stuff, like $19-20 per 11 or 11.5oz container. For me and my problem (almost exactly what you are describing above) it cleared it up real nicely. Not a silver bullet, but worth a shot.
Old February 7th, 2007, 10:55 AM
esprit99's Avatar
esprit99
Keith Imbriglio
Thanks for your input, I'll try it. Anyone have any other ideas.
'16 RRE
'04 Disco
Old February 7th, 2007, 12:07 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Could be the infamous stepper motor (idle air valve)?
Old February 8th, 2007, 08:21 AM
esprit99's Avatar
esprit99
Keith Imbriglio
Probleme fixed
FYI removed and cleaned the stepper motor. Reinstalled the stepper and disconnected and reconnected the battery. Also running fuel injector cleaner in fuel. So far so good. Thanks for the ideas.
'16 RRE
'04 Disco
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
