Stalling problem and fault codes - Defender Source
Old July 22nd, 2004, 03:29 PM
James's Avatar
James
James Gall
95 D1, 4.6, 35's, Dana 60
My truck has been cutting out and stalling at various speeds. Once the truck comes to a stop after spuddering and backfiring, it starts right up. The check engine light comes on a throws a code for the IAC/stepper motor and coolant thermistor. I have replaced both parts and they appear to be working fine. What else could be causing this problem? I have also replaced cap, wires, checked for cracked vacuum hoses, checked base idle and timing, and replaced coil pack. 95 D1 with 4.6
Old July 22nd, 2004, 03:50 PM
CHeck to make sure the wires and connectors to the stepper motor and coolant thermistor are all still good?
Old July 22nd, 2004, 04:03 PM
more than likely your stepper, this has been beat into the ground at the www.discoweb.org you may consider searching thier BB as of 3:59pm est the d-web is working
Old July 22nd, 2004, 04:07 PM
I assume the intake area around the stepper was cleaned when it was replaced?
TPS, MAF, Fuel pump, bad O2 sensor would be my guesses.
First thing I would do is disconnect the MAF sensor and see if the issue goes away. Then check the TPS with a meter to make sure it cycles through smoothly. There are the most likely culprits if your only issue is stalling at idle.
Stalling at idle is a tough one as it could be so many things. Does it do it when hot? Cold? All the time? Is it random?
The fact that it has a 4.6 should be of little relavance assuming it was done properly (I assume it was chipped and retained the 14CUX style ECU).
Ron
Old July 22nd, 2004, 05:55 PM
James's Avatar
James
James Gall
9 out of 10 times it does NOT stall at idle. I have checked/replaced/cleaned most of what you guys have suggested. Fuel pump and O2 sensors are my next guesses. Other than the new engine and t-case, the truck has 200k on it. As far as I know, the O2 sensors have never been replaced, nor the fuel pump. Could the VSS or ignition amplifier have anything to do with the stalling?
Thanks for all the help.
Old July 22nd, 2004, 07:29 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Check fuel pressure before bothering with the pump. Also replace fuel filter and the regulator before the the pump, they're alot easier to replace and alot cheaper.
inspection problem and OBD2 artm Defender Technical Discussions 25 August 31st, 2009 03:44 AM
Fault code help mjekogian Defender Technical Discussions 2 August 5th, 2008 09:52 PM
Rough Road Sensor?? scubadanster Defender Technical Discussions 25 April 19th, 2007 02:00 PM
97'Nas Stalls out and dies WEMICHENER Defender Technical Discussions 26 March 31st, 2006 08:58 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
