Stalling on stop - rough running - Page 2 - Defender Source
Old February 1st, 2016, 11:02 PM
IACV.. they seem to work forever.. I doubt that is the problem if you replaced it and have exactly the same symptoms..
also IACV will not do anything for a CEL light..
mine still stalls occasionally -
TPS, also is normally a red herring - they work or don't
my list of things to do..
Check all wires for tightness and corrosion
check battery cables for tightness - Bad grounds can do all sorts of havoc.
Check o2 sensors - make sure they are not loose or damaged (feel them if they ae beat up replace them)
check main MAF hose for leaks
check other Vac hoses for leaks - age will kill them and they can develop leaks/cracks
you may have a Vac leak - the brake booster can do this as well. Mine needs to be replaced at some point - but it only is an issue every once and while.
Also.. Check ignition amp module
cap and rotor (if your rotor does not come off with the smallest of force - stop!!! - if it looks ok then its probably ok. You generally have to cut them off to prevent damage to the distributor)
do you still have the CEL 45 code?
95' D90 - daily driver..
Old February 1st, 2016, 11:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
So hard to guess, but my #1 is a vacuum leak, not a sensor. Cracked hose is first guess. After that, plenum leak. What else at idle? Let's rule out IACV, so speed sensor? Not likely, but next on list. But really, IACV, VSS, MAF, all pretty solid. You can't just idle and spray with choke cleaner to find a vacuum leak...but I'd still start there.
How many miles? Slowly a worn cam can even cause it... But that's a lot of miles...
Old February 2nd, 2016, 02:40 AM
Departing90
Sasha
95 D90
No it can't! A worn camshaf doent cause the CEL to come on. There is no sensor monitoring it!
Old February 2nd, 2016, 07:57 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Check main MAF hose connection. Check the underside for hole that can develop from steering shaft bolt that is too long and rubs on the underside of the MAF hose. I put a tire stem cap on that bolt to keep it from rubbing on the MAF hose.
Report back one you fix the problem
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 2nd, 2016, 08:48 AM
Originally Posted by Jon_Winningham View Post
Check main MAF hose connection. Check the underside for hole that can develop from steering shaft bolt that is too long and rubs on the underside of the MAF hose. I put a tire stem cap on that bolt to keep it from rubbing on the MAF hose. Report back one you fix the problem
Those hoses rot out underneath ... Probably from moisture pooling at the lowest point. So even if it doesn't look rubbed it may be leaking. A smoke test is probably a good idea.
Old February 2nd, 2016, 10:47 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I was referring to the idle/stall, not the CEL as per the original post. And yes, a worn cam can cause bad idle and stalling (and there are a host of other things that can as well). I see some posts mention code 45--but that wasn't from Greg so I don't know if that was just randomly thrown out there. Greg, did you ever check your code reader box in your footwell?
Old February 2nd, 2016, 10:58 AM
Originally Posted by gmuiter View Post
Hello - I have a 1994 D90 ST, about 95,000 miles. Recently the CEL light came on and it is running rough. Like its mis-firing...? When I come to a stop the idle dips very low and sometimes will stall.
this is why i out out the CEL 45 checks.. chances are that is what it is but until he pulls the codes there is no way of knowing.
the stalling issue may or may not be related. But the CEL problem needs to be resolved first.
Old February 2nd, 2016, 09:07 PM
gmuiter's Avatar
gmuiter
Greg
1994 D90 #1646
Originally Posted by wmatos1001 View Post
Isn't the Idle Air Control Valve what you just tried replacing? Or did I miss understand.
Sorry - I meant I will be checking Idle Air Bypass Port as per the recommendation of Overlander in post #11. Next it was suggested to check vacuum lines and ignition amp as per some nice PMs I received too.
Thanks for all the help thus far. I will report back as I chase it down so hopefully this string will help others in my predicament.
------ Follow up post added February 2nd, 2016 09:10 PM ------
Sadly I cant get to the code reader as the previous owner sealed all the electrics very nicely and completely in a plastic epoxy'd box. I will have to likely destroy the box to get to the code reader. Though, a small price to pay to fix the problem. Will report back ASAP. Thanks!
Greg
Old February 12th, 2016, 08:00 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
A few of the posts above alluded to the ignition circuit, but forgot to mention the distributor itself.
I started having the exact same problems as described by the OP above with the exact same engine. I ruled out vacuum leaks, intake manifold leak, MAF hose leak, etc. I have a brand new VSS, 2 new O2 sensors, and a new IACV. Cap, rotor, wires, coil, etc. all checked out ok.
If you haven't done so yet, check the distributor itself, mine turned out to be the problem all along. Water had gotten into it and had been sitting for a while with resulted in a corroded interior.
Changed that along with the amplifier, and it's now running like a top.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old February 13th, 2016, 03:26 PM
gmuiter's Avatar
gmuiter
Greg
1994 D90 #1646
I replaced the cap and wires. I tried to remove the rotor but it would not come off. I found this common link from Rovers North about that issue: https://www.roversnorth.com/info/45
I opted to clean the rotor tip and leave it in place. I used some steel wool and that cleaned it up a bit. I am concerned though as some owner previous to me has silicone'd up the seal at the cap (pic 1 below). The previous post, #29 here references a bad distributor as a potential issue. That seems to be a pricey fix. Hopefully not to be....
Next, what I was hoping was the culprit, was a major split in the Plenum Air Hose (pic 2 below)
Im not sure if I cracked it or it was that way but after a lengthy search for the part(s) (OEM: ESR1316 or Substitute part PHH100290) neither of which can be located, I decided to tape it with silicone tape. Sadly, this has not improved the situation.
Will try some of the other suggestions when the Polar Vortex recedes.
ID:	142329   Click image for larger version
Old February 13th, 2016, 06:10 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Greg: I have a source for a distributor and amplifier used for around $100. That's what I went with because the brand new parts are $$$, and because I want to eventually upgrade to an HEI setup. From the looks of your rotor and the silicone, I would say it's worth the expense to replace both parts and install a new cap and rotor as well.
You'll at least eliminate that as a potential issue. My 2 cents.
Thank you - Samer
2003 Discovery II
Old February 25th, 2016, 04:20 PM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
Had similar issue in RRC, ran great at hwy speed, but as soon as the engine speed dropped, it would want to stall. Starting was gruesome also. I was on a 1200 mile trip across country, and it started the trip fine, then progressively fell further and further out of time until I was doing 60 MPH and it cut out and wouldn't purr back to life.
My suggestion #1: Check the timing. Throw a light on it and see what happens. I had an ignition module that had fallen out of time(Badly). Replaced dizzy, amp, coil, etc and set the timing. All better.
Good Luck!
Old March 1st, 2016, 09:45 PM
gmuiter's Avatar
gmuiter
Greg
1994 D90 #1646
Hello - Small update and positive news. The stalling on stop issue seems to be resolved after I repaired the crack in the air tube from the MAF to the engine intake. The check engine light remains on and it is not running perfectly but it is improved. See pictures, I used silicon tape to repair.
ID:	143962   Click image for larger version
Old March 1st, 2016, 09:59 PM
that should hold until Ash does a run of the hoses.. or maybe permanent
Old March 1st, 2016, 10:31 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
How is it with all the original engines out there that nobody has made a replacement for these?!?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old March 1st, 2016, 10:50 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Like this?
http://www.defendersource.com/forum/...tch-60414.html
Old March 1st, 2016, 10:51 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by genie90 View Post
Not sure this is going anywhere...
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old March 1st, 2016, 11:37 PM
I've got one of ash's in my truck...
He just need to do a second run of them
Old March 2nd, 2016, 08:23 AM
You mean like that run of hoses he supplied to a bunch of people?
Old March 2nd, 2016, 08:36 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Yeah the ones that didn't fit well hence the reason he was trying to get his supplier to produce the updated design per his last post in October.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
top
Stalling, stalling and more stalling !!!!!!!! DucatiChick Defender Technical Discussions 11 October 8th, 2012 04:59 PM
Help.. Tdi Suddenly running really rough TDI Guy Defender Technical Discussions 32 April 25th, 2012 10:37 AM
running rough Campbell Defender Technical Discussions 20 March 14th, 2010 04:33 PM
1988 RRC running really rough Davis Defender Technical Discussions 10 February 14th, 2010 01:17 AM
Engine running rough temporarily cgalpin Defender Technical Discussions 8 May 13th, 2009 01:45 PM
