Stalling Mystery ...or, MISERY !!?? - Defender Source
Old October 24th, 2012, 08:57 PM
DucatiChick's Avatar
DucatiChick
Christine
1994 Defender90
Exclamation Stalling Mystery ...or, MISERY !!??
OK, so I took my 1994 D90 to a VERY HIGH END EXOTIC place to get this pesky random stalling crap taking care of!
They cleaned the Mass air flow and idle control valve ( $ 214 labor ) .
It ran like a charm for a week but it has returned !
It has new spark plugs, battery, fuel relay, fuel pump, ECU blah, blah, blah !
They told me that when they had it on diagnostic that two "other potential " problems exist.
1. Idle something....lol ( part around $ 200.00 )
2. Mass airflow censor ( part around 1000.00 ) yikes !
The truck gives me no grief whatsoever early in the morning or late at night !
Air is heavier in warm weather "when it stalls", sooo, is it the M.A.C !!??
If so....does anyone have a fricking Air Flow Censor for less !!????
HELP....lol
Bewildered in Destin, Florida
Christine
Old October 24th, 2012, 09:27 PM
Grover's Avatar
Grover
Does it stall when approaching a stop?
Old October 24th, 2012, 09:29 PM
Idle control valve ...$40 part from autozone.
If they haven't change it then you've been overcharged and misled by your high end place.
Old October 24th, 2012, 09:36 PM
Please detail the circumstances of the stall. Does it happen when idling? Engine hot or cold?
The idle thing they are referring to is called a stepper motor. If this gets cruddy it can malfunction and stick. The one on your engine is the same as any mid 90s Chevy. Retail about $40-60. You can unscrew it with an adjustable wrench and install the new one in less than 5 minutes.
It allows extra air into the engine on deceleration.
Another thing to check is the engine breather t piece. And check for vacuum leaks like cracked hoses. There are several hoses on the intake that can appear good but really have breaks in them. Can cause rough running and stalls.
Cleaning the mass air sensor is pointless. Cleaning a 40 buck part and reinstalling it is ill advised.
Old October 24th, 2012, 10:03 PM
Grover's Avatar
Grover
Idle air control valve from pep boys: Borg Warner #21738
Old October 24th, 2012, 10:39 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Christine, you have by far the coolest Avatar image
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old October 25th, 2012, 07:49 AM
Does your speedo work?
Old October 25th, 2012, 10:47 AM
Used MAF are cheap.
Old October 25th, 2012, 11:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
I would also like to know the details of your stall. A couple of years ago I had an issue where my truck would almost stall coming off the highway etc. I changed the stepper motor, brought the truck in with no one being able to fix it. Finally I switched the maf with another truck and the issue went mostly away.
Now I dont know how your truck is set up but I think the issue with mine was the borla and a k&n air filter. When I put the stock filter in the issue never came back. Mlorman had the exact same issue with his last 90 and removing the k&n fixed it as well. He also had a borla.
Just something to check.
Old October 25th, 2012, 11:51 AM
K&N suck as they get oil on the MAF.
Old October 25th, 2012, 11:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
Finally threw mine away yesterday. I was saving it for some reason.
Old October 25th, 2012, 11:59 AM
I still have mine too. Not sure why other than I am a terrible hoarder and I figured someone with a Tdi might want it.
Old October 25th, 2012, 12:08 PM
It needs to be properly diagnosed...... This is why people are asking for more details on when it happens. For instance, it could by the VSS as that sets the two different idle modes.
Old October 25th, 2012, 12:13 PM
ini88's Avatar
ini88
Daniel Marcello
Is your coil getting very hot? I had a weird issue with mine with a hot coil. It would not put out the right voltage for the spark when hot and it stumble to the point of stalling.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old October 25th, 2012, 10:11 PM
DucatiChick
Christine
1994 Defender90
Hasn't worked in Years !
------ Follow up post added October 25th, 2012 09:12 PM ------
Why thank you so very much
------ Follow up post added October 25th, 2012 09:14 PM ------
Yes and at slowing down from a high speed ! ( totaly random )
------ Follow up post added October 25th, 2012 09:15 PM ------
Thanks, I'll give them a call !!
Old October 25th, 2012, 10:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do you have a k&n?
Old October 25th, 2012, 10:43 PM
Check the vehicle speed sensor.
Old October 26th, 2012, 03:09 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Yep, sounds likely to be VSS to me. It is probably throwing a code too. I don't remember the which code but i can check when I get back to my truck since mine is broken now too!
Old October 26th, 2012, 05:46 PM
My VSS is throwing a code and it doesn't seem to be too troublesome. Perhaps I just catch it on the throttle.
Old October 26th, 2012, 05:51 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Check your coil (ignition module) and make sure that the spade connectors on the bottom have a good connection and are not loose. I converted mine to ring terminals for this very reason. If something comes loose, your engine will cut off immediately until it's reconnected (or arcs).
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
stalling and sputtering roverboy Defender Technical Discussions 7 November 4th, 2004 04:19 PM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
Defender in Paris, and Mystery Guest Doug Misc. Chit-Chat 20 June 18th, 2004 01:52 PM
That mystery box by the gas tank. wicks Misc. Chit-Chat 7 April 2nd, 2004 07:43 PM
