stalling issue - Defender Source
Old July 31st, 2008, 01:31 AM
justinaldi
justin aldi
none
stalling issue
I would like to make sure that I am going in the right direction on my 95. Upon dropping the clutch my truck seems to dye out and stall. This happens on a radom basis, regardless if the truck is hot or cold. No engine light comes on, and the truck starts right up again. This has become a more common issue in the past 4 weeks.
During normal driving the truck runs perfect, no smoke, no missing, just perfect.
Any ideas what, where I should start?
Justin
justin@firstsecuritylending.com
Old July 31st, 2008, 11:15 AM
durangorover
Chris Wherry
1995 D-90
Check this out...
http://www.roversnorth.com/web/downl...le-air-gap.pdf
I haven't tried it yet. Mine is doing the same thing. I haven't found a good Rover mech. here so I've been slacking on getting it done. Check other threads on "stalling when coming to a stop?"
Hope this helps. Let me know if it works.
Old July 31st, 2008, 11:30 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Try to clean or replace the stepper motor. Reset the base idle too. If your base idle is set properly it should never stall unless there was a serious fuel or ignition problem.
Old July 31st, 2008, 12:26 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
When I recently got a full service and install of SS oil lines at a Land Rover Dealership, they reported that she was stalling at times.
After trying a number of different things including looking at the stepper motor they found after many other "investigations"
that she needed a new Mass air flow sensor. She's working fine now knock on wood.
That might be another possibility. Hope that helps
Gery
Old August 1st, 2008, 11:29 AM
midturtle's Avatar
midturtle
Wes
'95 90 SW #234
sounds like the transmission is shot. lucky for you I have an extra lying around
Old August 1st, 2008, 11:57 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Not pretending to be an expert....but how would transmission affect stalling?
Would think that engine power would not be affected "by itself", ie idling, RPM, etc.
Would think transmission would have symptoms of getting power from engine to wheels, ie clutch slipping, crunching, etc.
Is there a "link" that would affect engine from transmission fault?
Old August 4th, 2008, 12:26 AM
justinaldi
justin aldi
none
tranny?
i agree, how can the tranny play any part of this issue?
Old August 5th, 2008, 01:59 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
I think Wes was just being funny.
Strange stalling issue. Captain Spalding Defender Technical Discussions 4 September 9th, 2009 11:55 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
