stalling - Defender Source
Old May 6th, 2005, 02:25 PM
bjenk
Brian Jenkinson
1994 D90
stalling
I just did some searching to see if there is a solution to my little stalling issue. However, my 94 d90 is stalling every once in a while. Usually happens when I come to a stop or more often when I turn sharp at a slow rate of speed. I have not check anything as I am at work. But it does not do it everytime. Most of my searching found guys having stalling issues at all times. Other than the little stalling (maybe once during a little run to the store) the truck runs great. Any suggestions or related symptoms is appreciated.
brian
Old May 6th, 2005, 02:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
STC-1856 Ignition module relocation kit. On my third now (due to a faulty alternator) but am also running a heat sink on the plate.
Old May 6th, 2005, 04:39 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Not to throw cold water on the advice above, but when my truck was stalling periodically a tune-up, idle adjustment, and intake cleaning service did the job. There can be a variety of reasons, but many have experienced this problem.
"Uhh...I think they all leak like that."
Old May 6th, 2005, 06:24 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Exactly right, Robert, I'd assumed that he'd done that, but in re-reading the post, I guess not. plugs, wires, cap, rotor, clean stepper, MAF and intake. Failing all that, test ignition system per the workshop manual. After my module failing so many times with the same symptoms and no check engine light, my knee jerk is to go to the module.
Tony
Old May 7th, 2005, 12:40 AM
bjenk
Brian Jenkinson
1994 D90
Thanks for the input. I will do the above and just give it a once over with routine cleaning...What is the MAF?
Old May 7th, 2005, 12:56 AM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
mass air flow sensor...I think
Stalling problem HELP esprit99 Defender Technical Discussions 6 February 8th, 2007 08:21 AM
Stalling RR? headdamage Defender Technical Discussions 5 March 20th, 2005 12:29 AM
stalling and sputtering roverboy Defender Technical Discussions 7 November 4th, 2004 04:19 PM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
Why is my D90 stalling? JRowe Defender Technical Discussions 4 November 10th, 2003 04:17 PM
