Stalling - Defender Source
Old September 6th, 2012, 06:06 AM
Keebler's Avatar
Keebler
Kenneth Elliott
1994 D90 AA yellow (NAS)
Stalling
My D-90 Stalls when the clutch is depressed. It was throwing a code of 19.
I swapped the Mass air flow sensor and disconnected the battery to clear the code.
Now when approaching a stop and the moment I disengage the clutch, the RPM will stumble down to 250 or so. (will occasionally stall out completely if the A/C is on)
Does anyone have any suggestions?
-Ryan-
Old September 6th, 2012, 01:23 PM
Idle control stepper motor ... $40 autozone.
reset ECU after installing.
Old September 6th, 2012, 03:11 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I had a similar problem and resolved it after cleaning all the PCV hoses, the flame trap and the points where the PCV houses entered the throttle body.
Old September 6th, 2012, 05:26 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
If you can get the AC Delco go for that. I've had better luck when them than other stepper motors.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old September 7th, 2012, 04:58 PM
Keebler's Avatar
Keebler
Kenneth Elliott
I replaced the Stepper 2 months ago.
I don't think that is the issue. Only because i can leave the driveline engaged until 650 RPM (about to stall) then I disengage the clutch and the RPM will surge up to 1G. so it seems like its doing its job at the low end when given enough time to work.
My new Stepper is a "All Makes 4x4"
Maybe completely unrelated. But, My Speedo quit working the moment before the engine started stalling.
------ Follow up post added September 7th, 2012 05:01 PM ------
I don't think the transducer is plugged into the ECM... or that it could cause an issue.... However, Never hurts to ask.
-Ryan-
Old September 7th, 2012, 05:31 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Mine does the same thing, speedo too, but only occasionally.
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Stalling RR? headdamage Defender Technical Discussions 5 March 20th, 2005 12:29 AM
stalling and sputtering roverboy Defender Technical Discussions 7 November 4th, 2004 04:19 PM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
Why is my D90 stalling? JRowe Defender Technical Discussions 4 November 10th, 2003 04:17 PM
