Stainless steel fuel lines for a NAS 110 - Defender Source
Old June 3rd, 2013, 03:49 AM
Seems like both AB and RN are getting 650-750 for a set. Seems crazy for some fuel lines. Any more cost effective options?
Old June 3rd, 2013, 05:12 AM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
I have few left for 110, text or call me later...
Sal
Old June 3rd, 2013, 07:38 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The copper-nickel line from NAPA. It's designated brake line but can't see any reason it wouldn't be fine for petrol fuel line.
Brake Line - Universal Copper Nickel Hydraulic, 3/8"; 25.0'
Product Line: Balkamp
Compare BK 6413353
Brake Line - Universal Copper Nickel Hydraulic, 3/16"; 100'
Compare BK 6413348
Brake Line - Universal Copper Nickel Hydraulic, 3/8"; 100.0'
Compare BK 6413354
Brake Line - Universal Copper Nickel Hydraulic, 3/16"; 25.0'
Compare BK 6413347
Brake Line - Universal Copper Nickel Hydraulic, 1/4"; 25.0'
Compare BK 6413349
Brake Line - Universal Copper Nickel Hydraulic, 5/16"; 100.0'
Compare BK 6413352
Brake Line - Universal Copper Nickel Hydraulic, 5/16"; 25.0'
Compare BK 6413351
Brake Line - Universal Copper Nickel Hydraulic, 1/4"; 100'
Compare BK 6413350
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 3rd, 2013, 08:53 AM
I can't say what is right for your needs, but I used the cupronickel tubing from FedHill for my fuel feed. For the return I used the clear nylon. 5/16 and 8mm respectively.
Since I have only barb fittings on the tank, there is a short bit of regular rubber fuel line that connects the tank to the feed. same at the front where it connects to the fuel lift pump. The return line was simply pushed onto the 200 tdi banjo fitting's barb and run back to the tank barb.
If you choose a hard line for the feed, there is very little in the way of AN fittings for 5/16ths. I did buy a line nut that will let me put a NPT adapter on the end, and then use the braided stainless and AN fittings to make the connection to the lift pump, but it was going to cost like $80 for just that short run, so I opted for a buck's worth of rubber hose.
Old June 4th, 2013, 12:27 PM
Frank84
Frank Battersby
95 D90
I used the copper nickel line from my mom & pop parts store for fuel on my Tdi RRC - no issues and was easy to work.
'95 Soft Top
'89 Classic Tdi
Old June 4th, 2013, 01:41 PM
The problem I have is that unlike a diesel which runs at very low PSI until the pump, a gas motor runs at higher pressure and I am not comfortable with barbs and clamps near the motor so I need crimped rubber to steel fittings.
Old June 4th, 2013, 01:54 PM
I dunno what you are using for fuel delivery at the engine, but the fuel line on the RRC is 5/16. You can cut off the end that has the olive, run down to Ace Hardware and score a new 5/16th olive, and reuse the old nut and new olive on the new hard line to make your rail connection. puke line can be any old fuel resistant schmidt.
Old June 4th, 2013, 11:18 PM
Antichrist's Avatar
Antichrist
Tom Rowe
What the heck kind of fuel system are you running?
You can get barbed fittings that handle 300psi.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 5th, 2013, 12:07 AM
After losing an engine in the lotus due to an oil cooler line failure I am paranoid.
Old June 5th, 2013, 08:36 AM
Antichrist's Avatar
Antichrist
Tom Rowe
http://www.mcmaster.com/#yor-lok-tube-fittings/=n25x1u
Good to over 1,000psi.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Stainless Fuel lines MAX711 Defender Technical Discussions 2 July 7th, 2011 03:05 PM
WTB: NAS 110 steel wheels!!!! Blakesrover Wanted 1 October 10th, 2009 04:14 PM
WTB: 1- NAS 110 steel wheel mud ruts Wanted 1 January 27th, 2009 07:20 PM
NAS Defender 110 lrnasd90 For Sale - Vehicles 9 October 29th, 2005 02:01 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
