Stainless Steel Exhaust Rusting? - Defender Source
Old June 8th, 2016, 08:32 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
In october I had my local muffler guy bend me up a stainless steel exhaust. I noticed today that not only is it covered in surface rust, but a magnet sticks to it just fine. Correct me if I am wrong--a stainless steel exhaust shouldn't be rusting and a magnet should not stick to it, correct? Of it it has a little iron in the stainless, it may stick, but only just slightly (maybe with a 304 or something)? Just double checking before I call him tomorrow...
Old June 8th, 2016, 08:44 PM
"Stainless" rusts. Only the really nice stainless does not rust. A borla will never rust. And NRP will.
Old June 8th, 2016, 08:49 PM
Landy_Andy's Avatar
Landy_Andy
Andy
All depends what type & grade, some st/st is magnetic as it has a higher iron content. What did they quote you they would use ?
Old June 8th, 2016, 09:09 PM
My original Borla rusted but they replaced it for free and I haven't had any issues (with the exhaust) since then.
Old June 8th, 2016, 09:38 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
A quick google search said t409 and t304 are best. There are different types for different uses. Not all S/S is created equal. What grade did you get?
Old June 8th, 2016, 09:44 PM
It is probably 409. It will be magnetic and will rust.
Old June 8th, 2016, 09:53 PM
Interesting. The flanges rusted on mine but the pipes were perfect.
Old June 8th, 2016, 10:03 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
The better stainless like 304 has greater nickel content and less iron... Less iron means less of the normal type of oxidation/rust.
Old June 8th, 2016, 10:09 PM
Yep, 400 series stainless. Martensitic stainlesses have inferior corrosion resistance compared to austenitic grades.
This is why I cringe when people say, "I got a stainless exhaust, man." Oversimplification
That said, the rust you see in 400 series exhausts can be removed quickly using mild phosphoric acid solution, which passivates the surface...for a while. Internally, the 400 series stainless is superior to mild steel, but cosmetically there is a price.
Old June 8th, 2016, 10:44 PM
REDrum's Avatar
REDrum
Niall Johnson
1970 Series IIA 88 - Sandstone
316L or it will rust, which is made to order only.
I'm starting to come around to the hard logic, many have been trying sell me, that high quality galvi pipe last longer than 304 stainless pipe; for years I've been in denial....
Toltec Coffee Team:
'99 UZJ 100 - for glamping and grocery getting
'94 FZJ80 - our Costa Rican coffee mule
'96 FZJ80 - 3XL, racked, shaved and dipped in Raptor coat
'70 Petrol SIIA 88 - a Costa Rican expat now with US citizenship!
'70 Petrol SIIA 88 - for Central America surf & coffee exploration
'56 Petrol S1 86 - a whole new kind of land rover hell...
Old June 8th, 2016, 11:44 PM
304 should be fine as long as it is properly passivated after welding. 316 is a bit of overkill.
Zinc melts way below exhaust temperatures, so is not good coating.
exhaust
FS: Magnaflow stainless Steel Cat back Exhaust (NIB) RRC - VA, US pl626 For Sale - Parts 10 November 17th, 2014 06:16 PM
De-rusting chemical warfare o2batsea Defender Technical Discussions 7 November 23rd, 2011 10:12 PM
Rusting Bulkhead on a 110 Spectre Defender Technical Discussions 8 April 22nd, 2007 09:41 PM
Anyone POR-15 their wheels to keep them from rusting? solihul Defender Technical Discussions 4 November 9th, 2005 05:03 PM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
