Stainless Steel Bolt Kits. Good idea? - Defender Source
Old January 4th, 2016, 09:59 AM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face Stainless Steel Bolt Kits. Good idea?
Hello,
I have a 2000 TDi 90 Soft Top in Tobago, with only 30,000km! (Caribbean)
But the tropics destroy metal down there.
I need to replace most bolts, I have seen some Stainless steel kits.
Is this a good choice? I have heard rumours or "electrolysis" and bad reactions with the aluminum.
Please advise, and also suggestions would be great on specific kits for the doors, seats etc..
Old January 4th, 2016, 10:23 AM
Suggestions would be to search here and elsewhere as the decision to go stainless depends on the application. But yes you should of course isolate your aluminum from your steel.
Old January 4th, 2016, 11:15 AM
K2atlanta's Avatar
K2atlanta
Kevin
1983/Defender110
I bought a kit from these folks in the UK and was really impressed.
http://www.a2stainless.co.uk/Land-Rover_B2142O.aspx
Old January 4th, 2016, 12:20 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Land Rover
Yup, Stig Fasteners is great.
Jeff, I would recommend a good lick of anti corrosion paste on any stainless hardware you install.
Old January 4th, 2016, 12:36 PM
WestCoastRover
Jeff
2000 TD5
Great info guys.
Looks like a2stainless.co.uk have some good kits. Will message them about a Soft-Top 90 kit.
I will be bringing new seat rails to, so I will pair it up with this seat kit on eBay:
Defender Series Stainless Steel Seat Box Fixing Kit YRM 1039 | eBay
As for the Anti-corrosion paste you are referring to is something like this (not sure the best brand):
Ultra TEF Gel Tefgel L Anti Corrosion TG1 20cc Syringe Anti Seize Paste TG 1 | eBay
Thanks for the help!
Old January 4th, 2016, 12:44 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Jeff, you want to be careful buying anything from that Ebay vendor... do a search for Urban Land Cruiser on the site here, you will see why.
Locally, you can get those kits from Don.
Old January 4th, 2016, 02:03 PM
Nakatanenga.de makes far and away the best kit.
Old January 4th, 2016, 02:28 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
^x2^
Old January 5th, 2016, 09:55 AM
WestCoastRover
Jeff
2000 TD5
Smile
After some research, NAKATANENGA definitely has the most complete kit (380 piece - $150, compared to Stig Fastners 185 piece - $100) also included is the Anti-corrosion paste.
https://www.nakatanenga.de/zubehoer/...0-softtop?c=14
Will be ordering two kits today! Thank you again
Old January 5th, 2016, 11:20 AM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by WestCoastRover View Post
After some research, NAKATANENGA definitely has the most complete kit (380 piece - $150, compared to Stig Fastners 185 piece - $100) also included is the Anti-corrosion paste. https://www.nakatanenga.de/zubehoer/...0-softtop?c=14 Will be ordering two kits today! Thank you again
Their kit also has factory style heads on the bolts. It's the nicest I've seen.
Old January 5th, 2016, 11:22 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I couldn't read a dagone word of that Wiener Schnitzel... what does it say?
Rent my
Old January 5th, 2016, 11:25 AM
down_shift's Avatar
down_shift
Russell
http://www.defendersource.com/forum/...tml#post345442
Old January 5th, 2016, 11:31 AM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by down_shift View Post
You can order their stuff from muduk without an issue.
Old January 5th, 2016, 12:51 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
The kit doesn't include anti-corrosion paste. It includes anti-seize paste which you definitely need with stainless hardware to help prevent galling:
FAQ: What is 'galling'
Anti-corrosion paste it to help stop galvanic corrosion between aluminum and the stainless. You should be able to get some from Nakatanenga, one of the more common is Duralac, which is hard to find here, but readily available in the UK and Europe.
Old January 5th, 2016, 12:55 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
Are these bolt kits for D90's only? Or are there other kits for 110's and other models?
Old January 5th, 2016, 03:15 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Yes: Edelstahlschraubensatz für Land Rover Defender 110 SW / 110 CC / 130 CC
https://www.nakatanenga.de/zubehoer/...10-cc-/-130-cc
Semper Fi!
Old January 6th, 2016, 07:44 PM
WestCoastRover
Jeff
2000 TD5
Cool
OK,
Now that the kit has been picked, I need your final answers: Is switching to Stainless bolts the best choice for tropical conditions if anti corrosion paste is applied as well?
The Defender in the Caribbean is exposed to a lot of extreme conditions.
Is the paste good many years to come or is it temporary?
Because of difficulty in parts I can't have the stainless causing the Aluminum to oxide there.
Just want to know if I am going to have problems in a few years or not.
Thanks again guys!
Old January 6th, 2016, 08:25 PM
down_shift's Avatar
down_shift
Russell
OK, Now that the kit has been picked, I need your final answers: Is switching to Stainless bolts the best choice for tropical conditions if anti corrosion paste is applied as well? The Defender in the Caribbean is exposed to a lot of extreme conditions. Is the paste good many years to come or is it temporary? Because of difficulty in parts I can't have the stainless causing the Aluminum to oxide there. Just want to know if I am going to have problems in a few years or not. Thanks again guys!
If concerned, back out the screws and reapply the paste if need. Probably could complete all of them w/in the hour. I spot check one or two each year with no issues found.
Old January 9th, 2016, 06:29 AM
Also, some locations are good for a hard plastic washer to isolate the fastener from the panel. The floor boards for example.
Old January 12th, 2016, 09:44 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I chatted briefly with Erik at L8 about possibly getting a group buy of that Nagasaki SS kit for D90.
Anybody interested?
edit: Nakaninga kit
Rent my
kit
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
110 Stainless Steel Brake Line Kits Now Avilable SafariHP The Vendors Loft 4 April 18th, 2011 06:38 PM
Stainless bolt kits rayfi Wanted 22 October 29th, 2008 08:26 PM
Stainless Bolt Kits for 90s and 110s Stmpede For Sale - Parts 33 March 17th, 2008 10:54 PM
Stainless Bolt Kits ronward Defender Technical Discussions 2 January 26th, 2004 12:57 PM
