Stainless or grade 8? - Defender Source
Old April 5th, 2013, 06:27 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Which bolts for the tranny mounts, front cross member, rear shock mounts etc. would like to use stainless but am worried it might have the same issues as when used on roll cage.
Old April 5th, 2013, 06:30 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Grade 8 and plenty of waxoyl - I swear by that stuff. Makes things come apart soooo much easier, ask ED
Mike Hammond
Old April 5th, 2013, 06:32 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
SS is not a good use for this at all.
Matt Browne
Old April 5th, 2013, 07:52 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
grade 8
good luck with your search
Old April 5th, 2013, 08:13 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
X2...
Old April 5th, 2013, 08:19 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
You can obtain high strength stainless fasteners, such as 17-4 PH, but they are very expensive. McMaster-Carr carries high strength stainless. Hardware store stainless bolts should be avoided and should never be used for critical applications.
If you are concerned about corrosion, check out McMaster-Carr's selection of "ultra corrosion resistant" Armor-Coat bolts and cadmium plated bolts. They offer Gr.8 Armor-Coat bolts and some Gr.5 cadmium plated bolts.
You will find that most automotive applications will use Gr.5 fasteners. Typically when replacing a bolt, I'll determine the grade of the original factory fastener, then replace with an equivalent.
Old April 5th, 2013, 09:12 AM
Bill Larson
Bill Larson
Grade 8 and plenty of antiseize. Moving to the SW will help as well.
-Jeff
To mention the quality of life enhancement, moving to the SW...Hell Jeff will even put you up and let you pitch a tent in the yard! lol...
Old April 5th, 2013, 09:19 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Grade 8 all the way. With antiseize.
-Ryan
Old April 5th, 2013, 10:07 AM
malaD90's Avatar
malaD90
Paul
1994 D90 ST
You should use the original spec whether it is 5 or 8 or whatever. The spec torque will pertain to the grade used.
"Beer has food value, but food has no beer value."
Old April 5th, 2013, 10:52 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thought SW meant station wagon for a minute.
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Interior Stainless Kits JimC Misc. Chit-Chat 32 December 11th, 2007 11:57 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
