stainless hardware kit - Defender Source
Old May 5th, 2009, 11:42 PM
hamiamham
mike
97 D-90
does anyone know where I can fit a stainless hardware kit with posidrive hardware to replace the rusting hardware on my 1997 D-90 Soft-top? thanks
Old May 6th, 2009, 08:07 AM
www.mudstuff.co.uk
or not, let me keep looking...
Old May 6th, 2009, 09:05 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
many kits available through the listed vendors...if you don't want to purchase entire kits, Fastenal, the box stores & chain hardware stores carry posidrive SS. For door hinges, you will need to grind the head slightly to fit, very simple/quick.
Old May 6th, 2009, 10:27 AM
61rover's Avatar
61rover
John Crouse
Stainless Fastners
http://a2stainless.co.uk/default.aspx
Highly recommend
Old May 6th, 2009, 11:41 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Originally Posted by 61rover
2nd, that is the best place I have found. Prices are very reasonable (esp. with the current exchange rate) and I have been very pleased with the fit and the kits come with EVERYTHING you need.
Old May 6th, 2009, 07:32 PM
hamiamham
mike
97 D-90
am i missing something; they dont seem to list pre-1998 defender soft-top
Old May 6th, 2009, 08:08 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Read the descriptions. IIRC you just use the SW one and have the upper hinge bolts for the rear door left over. Everything else is the same I think. They also have a tire carrier bolt set and a tub to rear cross member kit as well.
Old May 7th, 2009, 09:36 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
What parts are you looking for? The buttonhead bolts that hold everything together on the rollcage?
I ordered a complete set of buttonheads, washers and nyloc nuts from a local supplier in stainless...
Grand total: 72$ canadian.
When I took the hardtop off, I stripped some of the rivnuts out on the windscreen header bar. I replaced them all with stainless ones. - cost me $32 for 25 nuts (only needed 6, but who knows where else I may need one?)
Old May 7th, 2009, 10:47 PM
CDeWan
Clay DeWan
5.3L beastie
for what it is worth I am in agreement with Don and Paul as I purchased (and continue as the need arises) a bunch of stainless from Fastenal. As I take old bolts off, I just replace them with stainless.
Old May 8th, 2009, 12:58 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yes, I do this too for many things, but I have never seen the same bolts for the door hinges anywhere. Personally I just McMaster or Grainger as they are local and send a courier to my house the next day (or I can pick it up).
Old May 8th, 2009, 02:36 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
http://www.expeditionexchange.com/muduk/
Old May 10th, 2009, 05:50 PM
hamiamham
mike
97 D-90
thanks guys / ill check those sites out
kit
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
NAS Green TD5 Door Hinge Kit w hardware SafariHP The Vendors Loft 0 October 10th, 2009 08:26 AM
Interior Stainless Kits JimC Misc. Chit-Chat 32 December 11th, 2007 11:57 PM
Stainless hardware sommer_90 For Sale - Parts 9 June 9th, 2007 01:29 PM
Stainless Steel Hardware Kit boshea Defender Technical Discussions 53 September 4th, 2006 01:21 AM
